Cylinder head work
The difference from before was the ported head, throttle body and intake manifold, and the cams. It was never tuned before and I am still waiting for my grace period to be over to go on a dyno to get tuned.
No I didn't but c'mon now, how many evo's on evoM do you think had the same mods that I had before I had this done? hmmmm... a lot right? so if i wanted a baseline for just having a DP back, I could just reference that.
I hope they didn't port match the exh ports and exh manifold to the gasket. It's way too big, will put the exh port walls very close to the water passage and generally screw your exh flow, (which is the most important on forced induction engines).
I just wanted to see if you did a before and after comparo. Then we could see in hard numbers what the improvement was on your specific vehicle.
Glad you're happy though - that's the important thing.
There could be a 10-15 hp difference between your car and other car's.
Originally Posted by 954DRGSR
You would be surprised at the differences. Some cars come from the factory a bit stronger.
Thanks
Originally Posted by EVOONYOASS
Sorry man but you are some what clueless
but I'm not exactly worried about a 10-15 hp difference. If I was THAT **** then I would have dynoed it before hand.
Thank you for your insight
but I'm not exactly worried about a 10-15 hp difference. If I was THAT **** then I would have dynoed it before hand.I say this because the company that did this for you said you would gain X amount of power. You will not know the increase without knowing the Y (previous power) to the equation.
I'm glad your happy either way.
thanks. but i will post dyno numbers anyway and see where i stand in relation to similarly or better modded evo's. all i wanted anyway is to see how much horsepower i have now and how much i spent to gain it.
so, 3" dp was about $250
high flow cat was $235
exhaust was $400
labor was $0 coz i installed these parts myself.
so before the head package, i spent $885
head package was $1750
labor for head install was $450
gasket kit was $207
total for head install only is $2407
so total i've spent on the car (for hp gains, not including clutch) is $3292.
now all i need to do is go on a dyno and see how much i'm making.
exhaust was $400
gasket kit was $207
