New Clutch = bad syncro shifts Info needed!
Old Jun 11, 2005 | 04:52 PM
DizeLLx's Avatar
i have a problem wiht my 5th gear, it grinds when i shift form 4th to 5th in higher rpms is it syncros or pushrod has to be adjusted btw i have my oem clutch thnx
Old Jun 12, 2005 | 06:35 AM
smokedmustang's Avatar
There is a recall or bulletin on the 5ht gear syncros, take it to the dealer and get that replaced FREE. there is also one for 3rd and 4th gear, this is a WARRANTY issue you have, trust me! look at my car with mods etc... they took mine in and warranteed it. DONT adjust anything until you take it to the dealership first!!!!!!!!!
Old Jun 12, 2005 | 07:53 AM
4rcd6's Avatar
So, I shouldnt adjust anything as of yet but just take it back to the dealership where i got the clutch put in and tell them whats wrong and see what they say??? Thats kinda what im hearing........................................ Correct???
If it were the pushrod, does it take a lot of movement or just a lil bit down to the floor?
Old Jun 12, 2005 | 10:12 AM
Talking this will help
Originally Posted by 4rcd6
So, I shouldnt adjust anything as of yet but just take it back to the dealership where i got the clutch put in and tell them whats wrong and see what they say??? Thats kinda what im hearing........................................ Correct??? Yes you are correct
You are correct, DON'T do anything yet. All you have to do is take it in and say you are grinding in 5th gear. They are well aware of this problem, and will take the tranny apart and fix it under warranty! I guarentee it! tell them to check 3rd and 4th gear also. Tell them you say it on this site about a memo on these gears! The clutch should engage 1" off the floor, not all the way up!
take the car to any Mitshubishi dealer and tell them about the 5th gear, and whoever did the clutch, tell them what it is doing. who did the clutch? a pro or shadetree mechanic? did they bleed the system after the install? this could be your problem there. keep us/me posted!
my2c
Old Jun 12, 2005 | 10:14 AM
re-read above, I dont know how our answers ended up in the "grey-box" but my answer is above where it says "my2c"
Old Jun 12, 2005 | 10:27 AM
4rcd6's Avatar
ok..
THE DEALERSHIP DID THE CLUTCH!!!!!!!!!!!!!!!!!!!!!!!
I didnt have any issue before.. so i think the syncros are fine really just needs to be adjusted to a certain extent... RIGHT or WRONG???
Old Jun 12, 2005 | 12:26 PM
Talking
ok..
Wrong..... they know about the syncros in 5th gear, have them change them anyway, Mitshu dealers DO warranty their WORK, wearher stock parts or aftermarket. so they will foot the bill if they screwed up the install. I only thing you can adjust is the clutch pedal travel, nothing in the trans! Ask them what the bulletin is on the 5th gear syncros, If they act like they dont know, call me and I will have the service MGR out here, gladly fax him a bulletin on this. I got my 4th/5th/ and 3rd complete gears and syncros rebuilt as they got the memo/bulletin on them. Look at how my car looks: Search: "all vishnu owners check out photos.....thats how it looked when I drove it to mitshu, and they STILL warrenteed it!
Old Jun 13, 2005 | 12:21 AM
Evil EV0's Avatar
Well I'll throw this in. I had pretty much all my syncro's replaced per the TSB with the "fix" and at that time my stock clutch was pretty much dead 23K miles or so I had them put in the ACT HDSS. Well my 5th gear grind is back again and they will not warranty it now. They blame it on the clutch. The dealership is pretty cool about it but the district rep will not give them permission to fix it with the aftermarket clutch. It only lasted me about 3-4K miles before coming back and I couldnt get the car in reverse (well easily, it was very hard) from day 1 and I even called them back and let them know about it (from day 1)
Anyways I just thought Id throw that out there, they said if the car hasnt been warrantied they will fix it even with an aftermarket clutch, but once it leaves the dealership, thats it.
Old Jun 13, 2005 | 03:24 PM
painthorseblu's Avatar
RE: clutch pedal free play.
Here's what the Factory Service Manual, sec 21A-8 calls for: 4-13mm (0.16-0.51inch)
If you can't adjust the free play and keep the free play at this range or if the distance between the back of the clutch pedal arm at a point opposite the stopper on the floor (with the carpet removed) and the stopper cannot be kept at 4.5 inches or more you probably have air in the hydraulic system or a faulty master cylinder. Either of which will prevent the clutch from fully disengaging.
Also if you have an early 03 as I do you may have an improperly assembled gearbox. Mine was fixed under warranty. My clutch at 30k was fine but the gearbox was still toast.
Old Jun 13, 2005 | 04:18 PM
glgz's Avatar
I am almost in the same boat. All of my syncros have been replaced however the 5th gear grind is back. I don't think it is worth taking it in has mine only grinds when I go into 5th above 5k and has stayed that way for 14k miles. Also I am still on the stock clutch. From what I have heard talking to people the 5th gear grind is almost normal seems to happen to alot of people. I would only bother trying to get it fixed if it is real bad IMO.
Old Jun 13, 2005 | 06:15 PM
Evil EV0's Avatar
IMO if I was you I would take it back. My car was the same way at higher rpm only, but it slowly started getting to the point where its bad at almost any rpm. They told me if I had the stock clutch they would fix it again under warranty, I would recommend doing that, why not. Also if you do, make them give you a rental car, the first time I went in for the syncros they gave me a rental.
Old Jun 13, 2005 | 06:20 PM
marksae's Avatar
Hard shifting at high rpms is due to improper clutch adjustment is due to your clutch not being fully disengaged. This will wear your synchros out quick! Aftermarket clutches will need to be adjusted to work properly.
Old Jun 13, 2005 | 06:23 PM
Evil EV0's Avatar
Is there an easy way to adjust the clutch? Also I know my car was fine for the first few thousand miles then the 5th gear grind came back, its pretty pathetic IMO.
Old Jun 13, 2005 | 07:12 PM
marksae's Avatar
Adjusting the clutch is pretty easy once you figure out how to do it properly. You do have to crawl underneath your dash and locate the pushrod to adjust. You can find it by crawling underneath, moving your clutch pedal, and find the rod as it moves w/ the clutch pedal.
You can follow this procedure:
http://mywebpages.comcast.net/njdsm2/clutch.html
The pictures are for a DSM, but the same principles should appy to the EVO.
Just remember to leave a little freeplay at the top of the pedal travel. The FSM spec calls for 0.16 - 0.51" of play.
Old Jun 14, 2005 | 07:22 AM
4rcd6's Avatar
Well my syncros dont grind, mostly just like it sticks or delays before I can get into gear. By adjusting the pushrod you believe this will help the same problem I have?
