Are these Injectors worth buy?
Old Jun 14, 2005 | 02:59 PM
DCSilvrEvo's Avatar
Hey guys i just spotted these on eBay. I was wondering if they are any good or it somebody has them?
Just need some feedback. thanks!
http://cgi.ebay.com/ebaymotors/ws/eB...category=33554
Old Jun 14, 2005 | 03:01 PM
DCSilvrEvo's Avatar
bump
Old Jun 14, 2005 | 03:04 PM
smokedmustang's Avatar
You dont need injectors unless you have a LARGER turbo! dont waste your money yet. my2c
Old Jun 14, 2005 | 03:05 PM
DCSilvrEvo's Avatar
I will need injectors my WHP goal is 450WHP
Old Jun 14, 2005 | 03:16 PM
sgplancer's Avatar
not always true. I was hitting close to 95% duty with the stock ones before I installed my new turbo. I had upgraded the injectors to sard 700cc and it helped quite a bit on the duty cycle. Just my .02
Old Jun 14, 2005 | 06:41 PM
see my mods, and I will be getting the HKS 280's/ Alky/ and TME turbo, I still wont need the larger injectors/. Wairt till you get the larger turbo!
Old Jun 14, 2005 | 08:42 PM
nickracer9's Avatar
i'm running an aem with all the goods(280's) and at 19 psi and 7000+rpm my injector duty sometimes hits more then 100% duty cycle(11.5 afr's). i can't run anymore boost because of this. the stock injectors will run out with the stock turbo, more so in colder climates. if your running alcohol you would be fine cuz your pulling fuel out to get the afr's back in a normal range.
Old Jun 14, 2005 | 08:45 PM
SilverEvo8owner's Avatar
You can very easily max out the injectors on stock turbo.
Old Jun 14, 2005 | 08:48 PM
Widebandphillip's Avatar
yep, i'm up to 95+% on only 19 psi. I also limited boost because of this. Funny thing to all the people that say you don't need injectors, they all have vishnu stuff. I just took a look at that guy's sig and sure enough.
Old Jun 14, 2005 | 08:51 PM
DCSilvrEvo's Avatar
Yea exactly! So do u have any information about these?
Old Jun 14, 2005 | 09:14 PM
i personally wouldn't buy anything crucial to an engine off ebay. Depending on what turbo you use and how high you're going to rev, 680's would seem enough. But i like 880's just in case =) You can Pm me your setup and how high you're planning to rev and then i could make an accurate selection.
Old Jun 14, 2005 | 09:31 PM
ebbeast2005's Avatar
with stock turbo injectors made a HUGE diffrence. Im running 680s with a aggresive tune. I did it and its worth it.
Old Jun 14, 2005 | 09:43 PM
Gruppe-S's Avatar
RC Injectors are very good injectors. They have been around for a very long time.
Old Jun 14, 2005 | 09:44 PM
DCSilvrEvo's Avatar
REALLY. I think im going to hope on them then! 319bucks!
Sounds like a STEAL to me.
Thanks for your imput!
Old Jun 14, 2005 | 09:54 PM
Gruppe-S's Avatar
Make sure they are EVO specific tho.. double check w/ them first. or go to http://www.rceng.com/Default.htm
