APS Twin Vent BOV review
Old Jun 17, 2005 | 07:48 AM
shadow1's Avatar
Just installed an APS twin vent BOV. Previous BOV was a TurboXS H34 (recirculates into the intake). I'll start with the TurboXS piece. It worked pretty well. Actually held boost (1/2-1 PSI) better than stock. However, I got occasional bucking when I let off the throttle around town. No idle issues. Can't comment on fluttering since I still run the stock airbox and cannot hear the BOV. I tried 3 adjusting washers initially. Then 2, then no washers. Same bucking effect. No install issues either - bolts right on. Clears the fan shroud fine.
Now the APS BOV. Also bolts right on. I left the spring adjustment bolt the way it was right out of the box. Drivability is like stock. Normal idle. No bucking. No surge or flutter. I use the stock airbox so it's quiet too. The atmosperic venting only occurs under full boost. "PHOOSH" is most audible when letting off the throttle at 6000+ rpm. $240 well spent.
Old Jun 17, 2005 | 08:02 AM
eclipsegs2k1's Avatar
nice review, sounds like a good product
Old Jun 17, 2005 | 10:32 AM
li1p1aya's Avatar
Had mines installed a couple of days too, no problems of stalling and idling. Installed it right out of the box also. Great BOV.
Old Jun 28, 2005 | 03:15 PM
bigjhoney's Avatar
Questions about the valve.....The stock hose that connects to the nipple isnt long enough...is that just me, or you have to get a new one( bought the valve used)? When installed the valve sits on its side and the nipple is pointing torwards the ground correct? thanks
Old Jun 28, 2005 | 03:23 PM
ROGERV's Avatar
Aps Bov
the set srew will be facing the radiator,yes you have to replace that hose.
Old Jun 28, 2005 | 03:39 PM
bigjhoney's Avatar
So pretty much means nipple pointing to ground? correct?
Old Jun 28, 2005 | 05:21 PM
althemean's Avatar
At full boost it VTA and under part throttle its a recirculated system?
Old Jun 28, 2005 | 05:27 PM
ScorpioEvo8's Avatar
I had mine on for almost 2 months now. It awesome. Quality is great, sounds great. I have the adjustment screw out about 1/4 of an inch out. No stalls, no problem what-so-ever. In my opinion the best BOV out there.
Old Jun 28, 2005 | 05:34 PM
BoostWhore's Avatar
id have to agree mine works great
Old Jun 28, 2005 | 05:37 PM
mvm42699's Avatar
From: 85296, 99519, 96817,98310,07306,10461(HomeSweetHome), & 00739
Old Jun 28, 2005 | 06:58 PM
althemean's Avatar
Guys??
Old Jun 28, 2005 | 08:16 PM
shadow1's Avatar
Yes, you need a longer vacuum hose. It comes with the BOV new. But any auto parts store will have bulk vacuum line in the right size.
Old Jun 28, 2005 | 08:18 PM
shadow1's Avatar
At low RPM, it's 100% recirculated. As the revs go up (starting just before 5000) the BOV gradually vents some to the atmosphere. It never vents 100% though. Check the design on the APS website.
Old Jun 29, 2005 | 06:14 AM
althemean's Avatar
Read it numerous times before. Must have just missed that part somehow. Thanks.
Old Jun 29, 2005 | 11:53 AM
titaniumkingpin's Avatar
im very happy with mine also.
Can others tell me how far out their adjustment screw is out from the nut?
I've been playing around with mine.
1/4 inch seems like its set pretty soft to me.
