Hallman MBC on STOCK 05 MR
Old Jul 1, 2005 | 12:48 PM
EVO MR FU's Avatar
My car is totally stock power wise, I just ordered hallman mbc , my main purpose isn't to increase boost, but the get rid of boost tapper and try to hold 20.3(stock boost) till redline. I have read a few threads and searched seems to not have a direct answer to if this is do able. is it possible to eliminate boost tapper and hold at 20 or 21 and still be totally safe on a totoal stock 05??? any advice will be greatly appreciated.... I should be receiving it soon i would like to know before i mess with it TIA
Old Jul 1, 2005 | 12:56 PM
fsugatorbait's Avatar
You'll still taper ~1-2 psi at redline but it will be a night and day difference to the stock setup.
Old Jul 1, 2005 | 10:18 PM
EVO MR FU's Avatar
is it worth putting it on, when u say night and day difference you mean that its improvement over stock setup correct?
Old Jul 2, 2005 | 06:07 AM
Dr. SS's Avatar
make sure you have a boost guage before you put on a mbc.
Old Jul 2, 2005 | 06:37 AM
Yes, youll need a boost gauge though to get it dialed it.
Old Jul 2, 2005 | 10:43 AM
05-EVO-GSR's Avatar
You will hold boost fine in the midrange but it still tapers a little from 5-7k. Open up your exhaust first before you start messing with the boost.
Old Jul 2, 2005 | 04:38 PM
EVO MR FU's Avatar
Yes I have a boost gauge, I do plan on getting exhaust , but not yet though. thanks for the input guys
Old Jul 2, 2005 | 11:17 PM
Jakeg97's Avatar
yes its worth putting on. you will feel a small difference or stock setup. but i didnt feel any night / day difference; nor did my 1/4 mile time.
Old Jul 3, 2005 | 02:19 PM
EVO MR FU's Avatar
small difference or stock setup, so its worth putting I but I may or may NOt feel a difference at all
Old Jul 3, 2005 | 02:23 PM
tke_413's Avatar
It's less than $100, just put the damn thing on and see if you feel a difference. Obviously, it's a BOOST CONTROLLER which means you will hold most of the boost up to redline...meaning you will have a little more power. If this was a few hundred bucks it'd be worth questioning and re-questioning, but it's not...just put it on.
Old Jul 3, 2005 | 02:32 PM
EVO MR FU's Avatar
I will put it on, once i recieve it......I know its cheap and everything just wanted to see if there would be a difference also I was askin b/c i read somehwhere that if you mess with boost on a stock car may cause problems.
Old Jul 3, 2005 | 09:55 PM
ries's Avatar
mbc wont really do much without other supporting mods but it will help the taper a little bit..............
tbe will make a big difference
good luck and have fun
