Issues with the B&M short shifter...
Old Jul 2, 2005 | 07:54 AM
EVOlunchbox's Avatar
Question Issues with the B&M short shifter...
I have had my B&M short shifter (non adj.) for a while now, and I always felt like the forward gears (1,3,5) were spongy. Well my concerns were true when I had a trans. specialist test drive my car. He felt the same thing. My back gears (2,4) slide all the way in, no spongy feeling, solid.
He suggested that I return to stock. I most likely will go that direction unless anyone has a cure for this. Will shifter bushing help this? My only shifting mods are a stainless steel line and the short throw.
Any help on this would be greatly appreciated.
Old Jul 2, 2005 | 02:47 PM
Mike@Forge's Avatar
It almost sound like it's the linkage on top of the tranny that may have a loose cable-end or something that's giving it that feeling. Probably the side-to-side cable-end.
I doubt it's the shifter itself.
Check the linkage.
Old Jul 2, 2005 | 03:24 PM
cpdevo31's Avatar
i have the b&m short shifter, but i haven't had anyproblems. i replaced the underhood bushings with the 2pc brass kit from lancershop.com, and also put in a set of 8pc poly stiff shifter bushings
Old Jul 2, 2005 | 08:31 PM
4-BNGR's Avatar
Take some sand paper to the retaining upper cup and then lube the hell out of the cup and shifter ball. That'll take care of it. Slam away... I also recommend changing your fluid to Penz Synchromesh...
Old Jul 3, 2005 | 08:44 AM
boyd494's Avatar
did you choose the 45% reduction? if so, did you make sure you cut enough off of the shifter base so the cable has clearance?
these were a great help when i installed mine... https://www.evolutionm.net/features/...mfeatures/42/2
Old Jul 3, 2005 | 03:08 PM
I have the original shifter that doesn't adjust.
I'm will check the clearance on the shifter base. If there isn't enough I will cut or sand it down.
I just had the trans. built so it might be the linkage like Mike was suggesting. I want to cover all my bases.
Thanks for the help guys!
