Boost Drop Question?
Old Jul 2, 2005 | 09:12 PM
Nvr2old32's Avatar
Ok. I've read a lot about guys saying their boost goes to something, lets say 19psi and then drops to 17 or so. My car goes to 20psi and stays there until I let off or change gears.
Is this what the car is suppose to do or should it be dropping down slightly?
Thanks,
Old Jul 2, 2005 | 09:32 PM
TurboXtreme's Avatar
A stock evo 8 at 3500 pushes 19 psi, then when it gets to 6500 it drops down to 16 psi. Do you have any mods done to your car cause if you have a boost controller you def can keep the psi up to 20. But stock thats what it does. Hope that helps
Old Jul 3, 2005 | 03:35 AM
li1p1aya's Avatar
maybe the ecu was flashed?
Old Jul 3, 2005 | 08:12 AM
an0ther's Avatar
take it into redline and see if it holds. I have a mbc and mine still drops when I hit redline. Holds 21 to about 6000 and drops to about 18 or so.
Old Jul 3, 2005 | 10:00 AM
hydrofoam's Avatar
in stock form it should drop a little... with a boost controller it should hold boost strong all the way to redline
Old Jul 3, 2005 | 10:08 AM
sgtevo's Avatar
your lucky i got an oil cange and now it falls to 10psi
