Loss of Boost.
Old Jul 18, 2005 | 08:48 AM
WWEvoRS's Avatar
Loss of Boost.
i just recently installed a turbosmart dual port BOV, (red) if that makes a difference, on my car. everything worked fine. i didnt notice bogging or stalling issues or anything. When i floored it though, it felt a bit slower, so i did it again while looking at the boost gauge. the boost gauge read 1.2 - 1.3 bars instead of the usual 1.4 - 1.5
what im not sure abuot is wether the BOV has a leak, or my car needs to get used to the new BOV, or if the nasty weather up here had something to do with it(hot and very humid), or if its just becuase its a bigger BOV then stock, or thats it half vented half recirc(100% recirc stock). need help!!
also, i have a Turbosmart MBC. After i figure out the issue with the BOV and i install the MBC, could i run my car up to 20psi? or 21?
thanks in advance for any input
Old Jul 18, 2005 | 11:23 AM
sleet's Avatar
You probally have a leak, check all your clamps and hoses.
Old Jul 18, 2005 | 10:59 PM
WWEvoRS's Avatar
i checked the clamps and what not, and 1 wasnt tightend all the way and i tightened it hopeing it would fix. it didnt fix it. im still running lower boost.
Old Jul 18, 2005 | 11:04 PM
PunoEvo1337's Avatar
i have those same mods... and i am running 23-22psi, as far as the leak the stock clamps are weak id replace them, i had a little bit of leak caused by them on the intercooler pipe and on the recirc hose
Old Jul 18, 2005 | 11:06 PM
also i thought of maybe it increased the volume a little, did you try just dialing a higher boost on the MBC
Old Jul 19, 2005 | 07:00 PM
WWEvoRS's Avatar
yeah. the dial is turned up to the hard a lot.
