Porting the Forced Performance !0.5T
Old Jul 22, 2005 | 08:18 PM
KILTERMAN's Avatar
Does anyone know the reason why the FP 10.5T is a million times tougher to bur thru than the 02 housing? the 02 housing came out perfect ( gasket matched ) while the forced performance 1-.5T has ALOT of room to be ported for gasket matching. Normally I would say this is a good thing but this piece is destroying everything I throw at it, any one know why?
Also here are two crappy pics taken from a crappy cell phone of how much is able to be taken off this thing,its atleast 3/16th inch, some areas 3/8's .
Old Jul 22, 2005 | 10:43 PM
evo_dadi's Avatar
i would think since the turbo will see more temp change than the o2 housing it would be made solid.thats why you see more o2 housing crack under extreme heat than turbo housings.
Old Jul 22, 2005 | 11:24 PM
KILTERMAN's Avatar
And because of this would Porting it be a "bad" idea? I mean, you got like 3/16th all the way to 3/8's to match the gasket size.
Old Jul 22, 2005 | 11:53 PM
evo_dadi's Avatar
i dont thinks its a bad idea but just pita to do
Old Jul 23, 2005 | 12:04 AM
KILTERMAN's Avatar
major PITA, the material is like rock
Old Jul 23, 2005 | 02:11 AM
Erik@MIL.SPEC's Avatar
The 10.5 housing is made out of some material that is different. There's a mention of it on FP's site somewhere. It's AN something or other.
Old Jul 23, 2005 | 12:18 PM
KILTERMAN's Avatar
What exactly is the 10.5T measurement? I mean where are the 10.5 CM? wastegate area?
