Suddenly im rich
Old Jul 26, 2005 | 09:07 AM
si_eater's Avatar
Suddenly im rich
no i didnt win the lottery, just trying to get some suggestions on why my car all of a sudden started to run rich, my mods are in my sig. i can really smell the fuel when im coming to a stop or when i rev my motor, at first i thought it was my greddy type-s leaking so i swithced over to a aps bov no dice still rich then i thought it was my boost controller because it was hissing so i got a hallman no hissing but still rich i reset the ecu to see if it will relearn, nada, keep in mind i have a ttm dynoflash and it wasnt running rich when i first had the flash it was like a month after that it started. someone told me that it may be my o2 sensor since i was runnin w\out a tune for a long time or my sparkplugs arent cuttin it anymore,
help me
thanks
Old Jul 26, 2005 | 09:09 AM
Curt@MrLed's Avatar
Former Vendor
pull your plugs and look.. or get a wideband on the car too see if its running rich
Old Jul 26, 2005 | 09:22 AM
Warrtalon's Avatar
Yeah, Marco, I'd check or change out the plugs.
Old Jul 26, 2005 | 09:50 AM
si_eater's Avatar
thanks clayton and farmer, what should i look for when i check them
Old Jul 26, 2005 | 09:52 AM
Warrtalon's Avatar
To see if they're fouled (dark black and covered in soot). Copper NGK BPR7ES are only $6-7 for a set of 4 at the local auto parts store, so it's no real loss to put some in and check it out if you can't tell from looking at the plugs themselves.
Old Jul 26, 2005 | 09:57 AM
si_eater's Avatar
cool, i'll pull and change them, but would that really cause me to run rich
Old Jul 26, 2005 | 10:01 AM
RKT SHP's Avatar
you know i have the buschur stuff and i am running pretty rich too. i changed out my spark plugs and it didnt help one bit. but i have boost leaks all over the place. and so what i dont is T-bolted every coupling. and on the tube that connects to the turbo i made a header gasket and also put in high temp gasket maker. it didnt help so i went in and put a little bit of gasket maker inside of all the couplings and i still have leaks. now i dont know what to do.
Curt@MrLed's Avatar
Former Vendor
just put them in, warm the car up, run it hard through the gears, come right home, wait till it cools and pull the plugs.. if you need post a pic so we can see if you cant tell..
MalibuJack's Avatar
very bad misfire means very bad ignition, very bad ignition would result in unburned gas.. so its possible..
Could be a bad O2 sensor, or a major leak somewhere in your intercooler pipes (though it may be hard to find, and this is an unusual symptom), your MAF could be having a problem (check the connection)
Every so often, when I start my car by quickly turning the key, the MAF doesn't initialize fully, and it runs rich at idle and part throttle.. So befor eyou go too crazy, turn the key, wait a second, then start the engine.. And change your plugs first..
Old Jul 26, 2005 | 10:03 AM
Curt@MrLed's Avatar
Former Vendor
malibu, i thought you were running a stand-alone..
Old Jul 26, 2005 | 10:05 AM
mike1023's Avatar
what should evo run anyhow. like A/F and what not like 13.5 or somthing like whats safe and what is pushing it. like maybe need 101 on lean and rich
Old Jul 26, 2005 | 10:14 AM
Warrtalon's Avatar
Mike, don't jack the thread and try to speak intelligibly.
Old Jul 26, 2005 | 10:17 AM
Curt@MrLed's Avatar
Former Vendor
hey warr. are you in a bad mood today, youre as sarcastic as me today.. sorry ot.. but im helping the guy..
MalibuJack's Avatar
UTEC.. somewhere in between..
Old Jul 26, 2005 | 10:18 AM
Warrtalon's Avatar
Not a bad mood, this is normal. Mike just has a VERY BAD HABIT of going crazy with his questions, so I try to keep him in line. He's pretty good at listening, too, so it works out.
