RMR Intake Replacement Filter
Old Aug 1, 2005 | 01:16 PM
CuniTEVo8's Avatar
Hello,
I have a RMR air filter kit...I think it is time to replace the filter...just the filter, but I don't know where I can just purchase the filter....all theplaces I've seen sells the whole kit....
Also, I know the K&N filter you can wash and reuse...can you wash and reuse any other aftermarket filters, such as the RMR air filters?....
Can you put other aftermarket filters onto the RMR intake kit? Anyone else have a RMR intake, please let me know where you got your replacement air filter. Thanks.
Old Aug 1, 2005 | 01:58 PM
mooreboost's Avatar
Just use compressed air to clean it.
Old Aug 1, 2005 | 01:59 PM
4-BNGR's Avatar
Clean it with H2O and a mild detergent. Let it dry. Then apply K&N's filter oil on it. They make a kit available at your local car parts store. I've got the RMR filter and use the stock intake snorkle with it. Works great
Old Aug 1, 2005 | 02:29 PM
Mike@Forge's Avatar
It's says right on K&N's packaging not to do that!
Old Aug 1, 2005 | 02:31 PM
mooreboost's Avatar
Then conveniently enough right below that it tells you to buy THEIR cleaning kit.
Old Aug 1, 2005 | 02:35 PM
Mike@Forge's Avatar
You can CLEAN it with whatever mild soap and water you want.
It's only their OIL that you "NEED".
Actually, I have even seen people use K&N's without using any oil at all, but I don't know that I would recommend doing that.
Old Aug 1, 2005 | 04:05 PM
mooreboost's Avatar
I'm sure it still filters a million times better than a foam filter.
