Pressure drop during test = leak?
When i did my pressure test to locate boost leaks i found quite a few that were very massive. But i still noticed that when adding pressure to lets say 15psi or so, the pressure slowly drops. I have been listening and spraying water to see if i can find more leaks but it seems like there are none.
Is this normal when doing a leak test? BTW, im using a compressor set at 20psi and a home made tester with a tire valve at the end. So wouldn't it be able to hold 20psi strong for quite some time?
