Over filling oil
Old Aug 11, 2005 | 08:41 AM
nutrulz's Avatar
Over filling oil
What is the worst case and best case scenario for overfilled oil? Should I drain it immediately, or is there an overflow that will just leak out?
Old Aug 11, 2005 | 08:47 AM
Silver05Bullet's Avatar
would want to know that too.
Old Aug 11, 2005 | 08:51 AM
Synter's Avatar
There really is no "best case scenerio" for over filling your oil. Do you like to see oil comming out of your exhaust?
Old Aug 11, 2005 | 08:52 AM
nutrulz's Avatar
No, There is very light oil smoke coming from under the hood, almost unnoticable.
Old Aug 11, 2005 | 08:54 AM
Synter's Avatar
it's never good to over fill past the hash marks, lot's of reason's for this. none are good, but just fix it as soon as you can.
Old Aug 11, 2005 | 08:56 AM
nutrulz's Avatar
vague answers suck, give me some reasons, so that others might look up this post and actually get good info.
Old Aug 11, 2005 | 08:57 AM
GEARS's Avatar
If the oil level is too high if will cause the oil to get whipped into a froth of foam and lubrication will suffer. I wouldn't worry too much about it if you are a titch over.
Old Aug 11, 2005 | 08:58 AM
lookEVO's Avatar
you could lock up the engine. if too much is in there. you could be create a leak past the rings. oil gets in the cylinders. BAD
nutrulz's Avatar
Thanks, Gears, LookEVO
Old Aug 11, 2005 | 09:00 AM
lookEVO's Avatar
dont sweat it. Its not a HUGE deal. mine was worst case scenario. your gonna burn a lttle anyway. just try not to overfill it alot.
Old Aug 11, 2005 | 09:02 AM
shivaswrath's Avatar
do you guys fill exactly 4.8 or just top it to 5 quarts?
Synter's Avatar
Another reason is that the more oil you have in the car the more you have to cool off and the hotter your car will run, the less you have(or with in the designated level) the easier it is to keep the engine cool. More is not always better. Do you really want oil leakin all over your drive way.
Old Aug 11, 2005 | 01:07 PM
GEARS's Avatar
All 5 and never look back.
Old Aug 11, 2005 | 02:45 PM
bolsen's Avatar
It's worse to over fill than run low. If you've over filled, just drain a bit and recheck until it's dead on
Old Aug 11, 2005 | 02:53 PM
Evoryder's Avatar
yeah ...drain a bit out ... did you put 6quarts instead of 5? ... my evo takes 5 quarts exactly
