downpipe gasket help
Old Aug 12, 2005 | 12:52 AM
scherejs's Avatar
noticed that i have a leak where my dp meets the o2 housing. took it off and the thin metal gasket was mangled. i have a 3 inch dp that won't work with the stock donut gasket. what should i use? originally i was thinking of permatex rtv hi-temp copper, but realized it's only good to 700f.
Old Aug 12, 2005 | 10:43 AM
RallySport Direct's Avatar
Silver Sponsor
Ok well there are a couple things you can do. If the downpipe you are using uses a flat type gasket then it is probably the normal generic flange. On way to check is see if the gasket you had is the same as where the downpipe meets the cat. If it is you can buy a new gasket from our website here.
http://www.rallysportdirect.com/shop...230d415cdd4f31
Ben
