ANYONE EVER blown a hole through your Transfer case??
Old Aug 15, 2005 | 02:51 PM
Vishnu_Evo8's Avatar
I fear i have done so... i recently installed the rps twin carbon clutch, and vishnu's launch control and i did a 7k launch while building 12 lbs of boost and something very bad happened. I had no idea that teh rps clutch gripped this hard.. There was no give and i heard a terible sound like a rod going out or something. As it turned out the car drives perfectly.. it pulls hard no vibrations and goes into all gears perfectly. no sounds at idle, but makes a whining sound under accel.. it sounds like a blown diff but i have the cusco diff.. which i doubt would break under this type of launch. so that leaves the ring and pinion? i guess??? or the tranny. But to my dismay, there i a small leak (im talkin a few drops an hour) and its deffinitely diff fluid) which also smells like tranny fluid.
Anyone have any idea of what it could be that i have broken? Im hoping its teh ring gear as i have an extra one.
Old Aug 15, 2005 | 03:04 PM
lookEVO's Avatar
wow umm could be a seal and you T/O bearing. you should get that fixed,
Old Aug 15, 2005 | 03:16 PM
gsujeff55's Avatar
why don't you climb under the car and look?
Old Aug 15, 2005 | 03:28 PM
im a pile of trash thats why.. i really should. in fact i will when i get home from work..
to be honest im scared of what ill find. im takin it to a shop tomorrow.
Old Aug 15, 2005 | 03:41 PM
Robert_K's Avatar
Thats suck! Hopefully it something minor. I' replacing my diff w/ the Quiafe this weekend.
Old Aug 15, 2005 | 03:57 PM
craigbb's Avatar
i blew up a transfer case due to low fluid and it completely blew apart but didnt put a hole in it they usually keep all the damage internal..the ring and pinion are what goes first..you may be leaking fluid from where the output shaft exits the transfer case..
Old Aug 15, 2005 | 04:38 PM
platinumspecv's Avatar
OMG man. 7K ? R u nuts? Yea you blew your tcase for sure. It's fubared. Get a new one
Old Aug 15, 2005 | 10:19 PM
ive launched at 7k 30-50 times before.. its just teh rps grips so hard.
Old Aug 15, 2005 | 10:31 PM
Quickshifter's Avatar
learn how to slip the clutch, and its for sure your ring and pinion and u might have even damaged your front diff
Old Aug 15, 2005 | 10:42 PM
Zeus's Avatar
Cracked case...
Old Aug 16, 2005 | 03:05 AM
trinydex's Avatar
either something cracked... or if you're lucky... you just lurched everything so hard that some fluid burped out the overflow hole at the top of the tranny... and it's leakin' down a lil at a time...
