Idle Problems
Idle Problems
Hi, I heard that Evos had idling problems sometimes anyway, but mine have just started. I have an evo III and i put in an HKS SLD (Speed Limit Defensor to disable the 180km/hr cutoff) and after I did that when i turn on my A/C it idles weird. Sometimes it idles high then goes down to about 8-900 rpm. When I have the eco setting on it idles really low, about 4-500 rpm and almost cuts off. Anyone else have this problem? I will be getting a new ECU sometime so that should fix the problem but until then i dunno what to do. I don't wanna adjust the idle up any more cuz i don't want it to idle high when i have the A/C off. Should I reset the ECU and drive with the A/C on so it takes that into account when setting again? Thanks
Guest
Posts: n/a
Hi there
we havent got that problem because Euro / US spec Evos dont come with speed limiters, but resetting the ECU sounds like a good idea. Undo the battery for half an hour and plug it back.
Start car, let idle for 3 minutes, and switch on A/C and let idle for 3 minutes and see what happens.
Re: Idle Problems
good luck... (or u can be like me and just live with it for a while
yeah, i dunno. I don't really need the A/C too often right now, but with summer coming, it's gonna be really hot and i'm not sacrificing my comfort, lol. Thanks though. I'll probably reset the ECU and use the A/C when it gets hotter. Oh well, we'll see what happens, thanks though.
Originally posted by Claudius
Hi there
Hi there
Hmm, slight problem
Yeah, i'm just gonna reset it and see what happens. I can't take it to the dealer. I'm in japan and it's a little different here. I bought it used from a japanese dealer and the warrenty is gone. But i don't need them anyway, there's auto shops everywhere if i really need it. thanks though
The ECU is smarter than most of us think. I learned this out a few summers ago.
When you turn the AC on while idling, the AC is supposed to pick up the idle so that the extra parasitic drag does not drop the RPMs too low to where the engine will stall.
But there is one catch to the idle pick up. The ECU will only raise the idle when the speed sensor sends a 0 MPH signal. You see, I was the type of guy who unplugged the speed sensor so that my mileage would not go up. But without it, the ECU did not know that I was at a red light, so the AC would kick on and the engine would stall because the idle was not raised. I plugged the speed sensor wire back in, and just like that my idling problems stopped.
If you are having trouble with the idle, it may be because you modified the speed sensor somehow. Try to trick the ECU that you are always going 0 MPH or km/hr.
Jeff
Jeff
I am having the same kind of problems with my evo VIII and I have done o mods to it. Completly stock and when I have the air on at red lights it goes from 1000rpm to about 800rpm. Anyone have any ideas what this could be?
