Gauges question
Gauges question
My MR came with the factory triple gauge cluster. It shows voltage, temperature and boost. Now, I've forgottent what the temperature shows... Is it engine oil temps? Or maybe transmission oil temps? I cannot remember if I ever knew that for sure and I cannot find that info anywhere.... I'd appreciate some help from the cognoscenti...
Along the same theme, I noticed when I first got the car and during the first months of ownership (Nov '04 to June '05) that temp gauge rarely moved from the very lowest readings. However, during the last couple of very hot months, the gauge shows temps nearly up to the halfway mark of the gauge (can't remember the values and I'm too lazy to go out and look
) Anyway, any thoughts on those temps? What have other ppl observed along these lines?
Thanks in advance
) Anyway, any thoughts on those temps? What have other ppl observed along these lines?Thanks in advance
It's oil temperature. In the warmer months, mine will get up to about 90 C at the hottest, usually, it sits around 70-80 C. (If I'm remembering the numbers correctly)
If you do some more "spirited" driving, you can probably get it up higher.
Originally Posted by thadon84
youll really know its oil temp sensor when you go to change your own oil and have to fetch a new tool for the job haha
https://www.evolutionm.net/forums/sh...d.php?t=139174
Originally Posted by jbfoco
its tapped into the oil pan drain plug, when he said get a new tool he ment you can use a socket you have to use an open end wrench
Originally Posted by burningmoney97
get some new gauges
get some new gauges
like you know
anyways, as the poll shows.. aftermarket is better than oem
Anyway, there is another issue with the poll. Nowhere is asked in what way the OEM is better, as good or not as good as the aftermarket stuff. Are we talking aesthetics? functionality? accuracy? useability? price? ............ Surely you cannot compare a multiple function, large, beautifully designed $300+ boost gauge to the simple yet accurate OEM gauge.... As for the oil temp and voltage gauges, I cannot see any aftermarket stuff being any "better" (whatever that means) that the OEM gauges. Also, unless you spend a ton of money and time, your aesthetic results are not going to be as good, let alone better than the factory stuff. I'd say if the lighting of the OEM gauges was better, the package would be hard to improve given the space available. The lighting of those gauges is pretty cheesy though.....
Actually, the poll is not very well set up and will naturally bias the answers to the after market side. Out of the 4 multiple choice questions only one allows you to choose the OEM while the other three go from bad to worse...... If that is not a loaded poll, I don't know what would be.
the term "better" can be used for whatever the person reading the poll feels
what i was trying to get across to warr. that the oem , imo, gauges are "junk" compared to the a multiple function, large, beautifully designed $300+ boost gauge to the simple yet accurate OEM gauge. and from the poll it shows that the majority agree. i am sure the oem gauges are good, but not as good as an aftermarket gauge
how would you question the poll so that its "not loaded" as you call it?
