Exhuast and Intake cams
Old Aug 19, 2005 | 10:43 AM
smokey's Avatar
A quick question. Are the intake and exhaust cams built the same for 264's? meaning.....would you notice the difference between having 2 intake cams or 2 exhaust cames in your car?
If someone sold you two intake cams and said "here is your intake and exhaust cam"......would you know that there was a difference when you went to install them??
thank you
Old Aug 19, 2005 | 11:15 AM
Chris@nolimitmotors's Avatar
there are #'s on the cams, i think one cam says IN and the othe EX
btw if you did put both in at the same time, you bend a set of valves. it happened to turotrix. One cam was improperly packaged and a set of valves got bent
Old Aug 19, 2005 | 12:23 PM
smokey's Avatar
thank you. I was curious cause I found someone who make cams and I have one intake cam but I need an exhaust cam so that this guy can scan the dimensions and make the cams for me at a cheaper price. If they aren't the same than I need to find an exhaust cam. thanks for the info. greatly appreciated.
