View Poll Results: how to fix
Voters: 3. You may not vote on this poll
Help what should I do?
I just did my boost pressure test today.
I bought all the parts from ACE hardware for around $8.00
Man what a pain in the ***. Guess what? I found some leaks. The one I noticed the most was comming from Buschur lower I/C pipe. The one that they send with thier Delux FMIC.
So I started to take things apart. I had a problem with the same spot before. This is the problem I ran into. The wastgate is right next to/on the pipe. So I unbolted the wastegate and got the pipe on nice and tight with some high temp silicon.
Now I can get the wastgate to bolt back up. I can only get the top bolt on. What should I do? Take the lower pipe off and put a dent in the pipe so that wastegate will bolt back up. or try to bend the bracket for the wastegate? Or just leave the wastegate bracket with one bolt?
Thanks!!!
Thanks!!!
