Help Help blowing fuses
Old Aug 21, 2005 | 08:45 AM
PHILLY EVO's Avatar
Angry Help Help blowing fuses
I had the AEM and an alky kit installed and now I keep blowing the engine fuse.....and that keeps the car from starting........Now the f$cking thing blows the fuse when the ignition is turned on followed it back the first block of wires in the computer when that is disconnected it does not blow the alky kit is totally disconnected....any help would be great
Old Aug 21, 2005 | 06:09 PM
PHILLY EVO's Avatar
help
Old Aug 21, 2005 | 06:40 PM
IPS Mike's Avatar
Registered User
philly
what you are asking is hard to diagnose over the net.
Your best bet would probably be to take it to a place you trust to have them run through the wiring.
good luck
Old Aug 21, 2005 | 06:47 PM
PHILLY EVO's Avatar
Originally Posted by IPS Mike
philly
good luck
Hey thanks I was hoping someone ran into the same problem.....so I could save time........glad it happen today instead of at the shoot out
Old Aug 21, 2005 | 08:38 PM
timzcat's Avatar
That's easy.
You have a wire shorting out somewhere for one of the sensors.
Generally all your sensors are on the same power bus. So if an O2 wire shorts to ground it will blow the fuse and take out almost every other sensor on the engine. Find the one wire that is grounding out and you found the problem. The most common cause is in fact O2 wires burningon the exhaust.
