Help: NEED INFO ON WHINE (and thats not the good kind)
Old Aug 23, 2005 | 06:25 AM
Smike's Avatar
2005 Evo 8 GSR, 26000 miles, ACT clutch (about 1000 miles on it). It now whines from 0-20 mph or so, but stops after that. I have searched and searched, and the whining that I see is from blown t-cases, and I fear that statement. Id like to know what everyones opinion is. Here is the situation:
I had to replace the clutch because the dealer I went to sucks. The pick up on the pedal was getting high in the throw. It was there for an oil change, so I had them check the disc. They came back saying it only had 15% on it. I gave them the "ya right" look. Its my daliy driver, and it may have some mods to it, but 85% worn at 25000 miles, Id have to be riding the clutch (which I dont) to eat it that fast.
So, luckly, I was back in Michigan (hometown), so I went to my mechanic, we took it apart, and tada - the stock cluctch was fine. Still had about 80% of life left. And little to no dust, if anything it needed to be seated better with some harder runs. The line needed to be bleed. Dealer wanted $1600 for the job. Since I had the parts, it was $500 with my mechanic. But I already had the ACT clutch sitting there, so I swapped the disc and assembly in and removed the restrictor. I was going to do it eventually, so might as well then.
Drove 450-500 miles lightly to break it in, and then a few track runs (5-6) at Milian Dragway (and first time with that car at a track). Using the 5K limiter and feathering out the clutch. Aside from some slow times, do to me not shifting fast and having a boost leak, goes like a bullet, no burnt clutch smell.
But I now notice, after I have silenced my muffler for daliy driving, that there is a low whine when I come up to a stop (clutch in, out of gear, or stop and go - clutch in and in 1st gear), almost sounds like a supercharger, but not terribly loud. I dont hear it on the freeway, but the car generally is noisy. I drove the 650 miles from MI to NJ with my exhaust open, and didnt notice it at all. Now that its silenced I can hear it. And its been a few weeks since I have silenced it, so is that a "normal" sound or is my life about to suck?
Old Aug 23, 2005 | 06:42 AM
juyanith's Avatar
Are you sure it's the clutch? The main reason I ask is because you have a walbro fp listed in your mods. Next time you hear it, check to see if the sound is coming from your rear seat on the driver's side.
Old Aug 23, 2005 | 06:54 AM
Smike's Avatar
Thanks, I thought of that too. The fp has an electric sound. This is coming from the front half of the car.
