Test pipe and tune
Old Aug 24, 2005 | 12:09 PM
Warrtalon's Avatar
Originally Posted by Spec'd
That's a good question. ^^
I have a brand new Ultimate Racing HFC in the box.
I might install it once I put together my TBE.
By the way Warrtalon, what TBE do you have ?
I have the Megan 3" TBE with resonated TP courtesy of TheSpeedFactor.
Old Aug 24, 2005 | 12:13 PM
BBYBruno's Avatar
why does it matter if you check engine light is on anyway? i have a test pipe and my light is on, so what? just wondering.
Old Aug 24, 2005 | 12:18 PM
Warrtalon's Avatar
Several reasons:
1) It's annoying
2) What if you have a REAL problem down the road and the SES comes on for anothe reason? You won't even know, since yours is always on
3) Some states have inspections that simply plug into your diagnostic port to check for codes. If your SES light is on, you fail.
Old Aug 24, 2005 | 12:34 PM
Spec'd's Avatar
I was just curious.
Old Aug 24, 2005 | 12:42 PM
Spec'd's Avatar
There is a definitive way to eleiviate your SES.
The use of an O2Sim will work reliably without question.
I have done it to a couple of different cars in the past.
The only drawback is requiring that the factory wiring be spliced into as
there seems to be no harness available.
If I go the route of using an O2 Sim, I will most likely make a plug and play
harness, if I can obtain all the connectors required.
Perhaps an old O2 sensor harness ?
Old Aug 24, 2005 | 06:59 PM
Mystery's Avatar
I know the test pipe will throw the check engine light, I was planning on using either the Perrin or Helix which both come with there own "fix". I am not worried about the exhaust being loud (have JIC Ti cat-back) as I am wondering how much louder the exhaust will get with the downpipe and test pipe.
Thanks again for all the info!
Old Aug 24, 2005 | 07:09 PM
Spec'd's Avatar
Here is the exact same thing that Perrin sells.
https://www.casperselectronics.com/M...ry_Code=nissan
As for the noise being louder, everyone seems to agree that your Evo will
become louder. I can't vouch for that as I have the stock cat.
Old Aug 24, 2005 | 07:21 PM
accident's Avatar
try driving behind a car that is catless for awhile, maybe I'm more sensitive to it but my eyes get really irratated and water up. I feel sorry for all the people that drive behind me
Old Aug 24, 2005 | 08:37 PM
mooreboost's Avatar
The smell doesn't bother me at all. I dont even notice it with the windows open.
It shouldn't even be a concern for you.
Old Aug 24, 2005 | 08:44 PM
byt's Avatar
byt
Ah, I love the smell of toxic fumes in the morning!
Old Aug 24, 2005 | 09:02 PM
Gear Grinder's Avatar
Is there a lot of differance between a test pipe and a high-flow cat? except if you need to run higher octane leaded fuel.
Old Aug 24, 2005 | 09:03 PM
Old Aug 24, 2005 | 09:17 PM
evo_rc's Avatar
For a street car, is the performance increase worth the smell ?
hahaha hell yea!!! i just put a perrin last week. I can definitely feel it faster...I do smell it though, I kinda like the smell... if you have ww or any color besides black definitely buy the cf heat shield....it was polluting my rear bumper around the exhaust tip, i couldnt stand it. I had to buy one.....
TJFD
May 7, 2017 12:05 PM
joonvang
Jun 6, 2016 03:27 PM
evo4life94
Sep 11, 2012 03:28 PM
userwave
Jun 29, 2012 07:37 PM
matias04374
Jun 14, 2009 01:36 PM
