Installing Just a Clutch Disc....
Old Aug 26, 2005 | 02:43 PM
BaLListic_EVO's Avatar
Is this just a waste of time or would this be worth it? right now i have an RRE no name clutch and was considering putting an ACT disc in it... the no name disc is shot @ 20k miles... mostly daily driving.....
Old Aug 26, 2005 | 03:16 PM
bigjhoney's Avatar
IMO if you already there, might as well replace everything, remember half the cost is installing.
Old Aug 26, 2005 | 05:02 PM
well i can get it installed for 425$........... which isnt to bad or a may even do it myself.....
Old Aug 26, 2005 | 05:18 PM
spooledevo's Avatar
u can check and see if the pressure plate is in spec. if not in spec then replace everything
Old Aug 26, 2005 | 05:22 PM
hmmm in spec any idea where i can get these specs.... guessing from the service manual... which i have lost my copy of
Old Aug 26, 2005 | 06:18 PM
MaxR's Avatar
I know more than a few shady mechanics who have reused pressure plates and got away with it.
Old Aug 26, 2005 | 07:46 PM
Precision Dyno's Avatar
Please go with the pressure plate and clutch kit.
New Throw out bearing. Don't skimp.
It will not be worth it if you do.
My 2 cents
Old Aug 27, 2005 | 08:05 AM
yeah ill prob just get the full ACT kit.... it just sucks to use somthing for 20k miles and thats it... it be gone.... though i believe that the clutch was not adjusted properly in the first place so it was slipping alot....
Old Aug 27, 2005 | 09:08 AM
rburris28's Avatar
I just replace my clutch and did the math on the cost per mile-
Would you believe that the highest per mile cost for the Evo is tires?
Clutch: $1200 divided by 15,000 miles = 8 cents per mile.
Advans: $1100 divided by 8,000 miles = 14 cents per mile.
In your case, the RRE was even cheaper per mile, as it lasted longer.
Something to think about.
Old Aug 27, 2005 | 02:22 PM
the RRE sucked lol... it was a **** poor clutch from day one... i wouldnt ever purchase one again or suggest someone to purchase it...
Old Aug 27, 2005 | 02:51 PM
Toddevo 8's Avatar
if you think it suck that your clutch went out with only 20k. when you do the short cut on the clutch it will not last. if you have it apart do it all or dont waste your money.
Old Aug 28, 2005 | 01:25 AM
marksae's Avatar
I wouldn't mix and match parts from different clutches. There's a possibility that the pressure plates could be designed for different disc thicknesses. Some DSMers, back in the day, tried to use OE pressure plates on their ACT clutches and found out the hard way that the ACT discs were a little thinner (around .010" IRC). Their clutches would never fully disengage.
Old Aug 28, 2005 | 02:45 AM
144mph's Avatar
rburris, if you add the cost of gas to that, as well as small dollar stuff like fluids and brakes it's getting to be pretty costly IMO. Makes me want to drive a POS and save my evo for when I feel like a treat.
Old Aug 28, 2005 | 03:27 PM
ACTman's Avatar
I don't know if I would recommend what you are proposing without testing the pressure plate, but there should no problem with compatablity.
Old Aug 28, 2005 | 03:31 PM
Curt@MrLed's Avatar
Former Vendor
dont be cheap, do the job once and do it right..
