"Service Engine Light" on at 20,000??
Old Aug 27, 2005 | 12:27 PM
Nvr2old32's Avatar
Question "Service Engine Light" on at 20,000??
Ok,
I just hit 20,000 miles on my car and right then the "Service Engine Soon" light came on. Is this normal. I thought I read about this but don't quite remember. Can I reset the light myself or do I need to take it into Mitsubishi and have them do it. Wondering if I disconnected the positive terminal on the battery that this may do it.
Any words of advise greatly appreciated!
Thanks,
Old Aug 27, 2005 | 12:33 PM
Cabo's Avatar
It means you have a problem -- it is not supposed to come on @ 20k mile intervals.
I'd get it checked out.
Cabo
Old Aug 27, 2005 | 12:53 PM
bigjhoney's Avatar
Pull the code out and post it up, any local autozone does it for free.
Old Aug 27, 2005 | 03:50 PM
Kyoichi Sudou's Avatar
Yep, pull the code, so the guess work is not a factor
Old Aug 27, 2005 | 04:25 PM
evo racing's Avatar
lol most likely ur having misfires...yup u have an 03 i just got this problem at around 20,000 miles too...go get ur ECU reflashed...
Old Aug 27, 2005 | 05:04 PM
Nvr2old32's Avatar
Well, I took the positive terminal off for about 15 minutes and then rehooked it up. Light is off and I've driven about 25 miles and no light yet. It may pop back on so if it does, I'll just take it to Autozone to get it checked.
Thanks for the feedback.
Old Aug 27, 2005 | 05:06 PM
evo racing's Avatar
yeah it will come on again...after around 200 miles...the dealer charged me 78 bucks to erase the code and it came back on...then they flashed my ecu...
Old Aug 27, 2005 | 05:18 PM
gaijin's Avatar
20,000 miles? what took it so long? lol. mine has been on since the day I bought it.
Old Aug 27, 2005 | 07:19 PM
EngineChauffer's Avatar
Old Aug 27, 2005 | 11:23 PM
all stock's Avatar
reseting the code makes the light go away, it doesn't make the problem go away. you should of pulled it.
Old Aug 28, 2005 | 08:43 AM
FinsNCanes's Avatar
It's probably a misfire. I got the same thing and when they brought it up on the computer they said "How fast were you going when this happened" my reply of course was "Not fast really", they're reply after that was. . "somewhere around 105mph?"
Old Aug 28, 2005 | 09:01 AM
IXMR's Avatar
in order for your car to set a code it has to see the same problem more than once, the computer will also take a "picture" of the parameters EVERYTHING going on at the time the O2 the, throttle pos, the wheel speed, the vehicle speed, even if you air is on at the time. the code you set is probally still in the computer but you may have gotten rid of your way of seeing the code b/c you turned off the MIL (malfunction indcater light) the autozone scantools are not the best they basicly scan and erase they dont read ino the problem, o sorry, i just kept typing, ill stop now
