Aftermarket Header Q's
For people who have installed a new header alone, after the basics mods have been installed, i.e. 3" turboback w/HFC or test pipe for example.
What rpm are you achieving 1.4 or 20 lbs of boost in 3rd gear on a stock turbo? Please note if your running a 9.8 or 10.5 turbine housing.
My 03' stock made 1.4 bar @ 3,200 rpm, with the 3" tb w/hfc made 1.4 bar @ 2,800 rpm. I have read that headers supposedly decrease spool rpm anywhere beween -300/-500.
Are there people out there getting 1.4 bar boost @ 2,300-2,500 rpm with a 9.8 inconel wheeled turbo?
If so, which brand header?
Could you please describe your findings?
Would you recomend this mod?
Do hear more noise from the header?
Cost/Vendor of header purchase.
I know there are lots of threads that mention such findings, but a majority of the people installed other mods @ the same time which make it difficult to truely reveal the benefits of a aftermarket header.
Thanks
Thanks
https://www.evolutionm.net/forums/sh...9&page=2&pp=15
There is a dyno sheet from a header install. This is the best looking header I have seen for the Evo yet, and also one of the more expensive. However, in the graphs you can somewhat see when the turbo comes to life. It may be a few hundered RPM quicker.
From my past experiences headers make power, but thats on ZZ4, LT4, and LS1 engines. As for turbos, I believe they do help spool up times, and syncing of the firing cyclinders.
For noise - well on NA cars headers usually increase sound, but on ours with the turbo in the way, I dont think that it will be that much louder.
Hope that helps you get started with your header mod.
Ben
