front output shaft seal pn's?
I am having troubles locating the pn numbers for the 2 front output shaft seals coming from the t/c.
Does anyone know these?
Originally Posted by fullboost
I might be able to help, but I need a better understanding of exactly what you're looking for.
The seal that lives in the tc/front diff & goes around the cv joint that goes into the tc/diff......any help?
Thanks again
try looking here
https://www.evolutionm.net/forums/sh...d.php?t=124376
if you can't find it, then post the same (clearly worded) question.
the response is usually very quick.
Just Kidding! Had to do it. On a serious note, try this link and tell me what number/s you are looking at. Then I can get you the part number.
http://www.geocities.com/spadsm/Illust.tif
Does it live in a condo?
The refernece #30145 & 30146 look like them. I also need to verify if there is a o-ring or a seal that lives between the t/c & gearbox too.
Thanks
