headbolts required? for 380-400whp?
Old Aug 31, 2005 | 06:06 PM
yesevo's Avatar
do i need to upgrade headbolts if my goal is no more than 400whp?
thinking about putting alky kit on stock turbo. i know al recomends headbolts
but when u look at buschure david's rs....he dont have one.
both making close to 400whp/
i m confused. i dont wanna touch the headbolts .....
give me some feedback. thanks!
Old Aug 31, 2005 | 08:43 PM
evo81's Avatar
it doesn't hurt,but no needed.
Old Sep 1, 2005 | 12:26 AM
Roberto's Avatar
Yes... You need head bolts no matter what. You may even consider replacing those stock head bolts Mitsubishi generously threw in the deal for some nice ARP head studs at that power level.
Old Sep 1, 2005 | 12:47 AM
NocturnalEVO's Avatar
They're not expensive, i wouldn't risk it over $90 or so..
Old Sep 1, 2005 | 07:56 PM
yesevo's Avatar
more feedback please! when u upgrade the headbolts. i heard that u had to take the cylinder head out thats the proper way to do it otherwise u ll have some oil still inside the hole.
Old Sep 1, 2005 | 07:57 PM
evo_il8's Avatar
id do it as cheap insurance
Old Sep 1, 2005 | 08:03 PM
DragNRacing's Avatar
I would do it if you are going to boost over 24 - 25 psi on a regular basis. Head gasket too.
Old Sep 1, 2005 | 08:05 PM
MYEVOVIII's Avatar
I would cheap insurance $90 for bolts or a couple grand for a new head Ouch!
Old Sep 1, 2005 | 08:17 PM
crow's Avatar
I wondered the same thing. I have never heard of anybody streching the head on the stock bolts. If the car is tuned right, there should be no problem. everybody talks about having to change the studs, but knowbody can give me an exact reason. I've heard more people talking about how their apr studs were installed wrong, then stock ones going bad
Old Sep 1, 2005 | 08:18 PM
GOKOU's Avatar
Watch out because cheap insurance can turn into a major pain in the butt if you're planning to put the stud on using the 1 by 1 method.
I say if you're not running high boost constantly and don't have alky kit (tons of tq) leave the stock studs in there. You don't see too many people complaining about blown head gasket on stock studs. If you're removing the head then YES do it, no questions ask.
Just something to keep in mind.
Old Sep 1, 2005 | 08:56 PM
1.8t's Avatar
Exactly. Which is why I am on stock headbolts. 22.5psi daily for over 10k miles and no problems.
Old Sep 1, 2005 | 11:10 PM
inco9nito99's Avatar
FYI there have been 2G DSMs *(less refined heads than Evos) that have run ~27psi all day with a LARGE turbo pushing 500whp with stock headstuds. And for those who deny my input, go knock on AMS' door and ask about Victor or Jason Slusser . You dont HAVE to put headstuds unless you're noticing valve float.
Old Sep 1, 2005 | 11:15 PM
JP98SS's Avatar
That's a new one...thanks for the valuable insight! Did you change your muffler bearings recently?
Old Sep 1, 2005 | 11:25 PM
You win JP98SS.
Old Sep 1, 2005 | 11:41 PM
mooreboost's Avatar
You win JP98SS.
No, seriously, did you?
If not you could be fouling up your blinker fluid too.
I have had my ARP headstuds in for about 4k miles, no problems yet.
