Buschur Racing customer breaks our own records!
Old Sep 6, 2005 | 01:02 PM
  #31
TwStDeVo's Avatar
Originally Posted by davidbuschur
The stroker bottom end is $3500, whether I ship it or pre-build it here to put it in. That requires a core. If your car comes here I get my core when we pull your engine.
Dan charges $1500 labor to remove the old engine, disassemble it, clean EVERYTHING, re-assemble everything and put it back into the car. This does not include gaskets, $300, fluids $100, timing belt tensioner $145.
David Buschur
www.buschurracing.com
what kind of improvement can we see in spool up with the stroker kit?
Old Sep 6, 2005 | 01:08 PM
  #32
1.8t's Avatar
Originally Posted by cary
dave was the 2.0 liter that matt previously had stock or your stage 3 shortblock? if it was the built 2.0 how come his engine died after only 7k miles?
Judging from the fact that David had the rev limiter set at 10k rpm on the 2l and the fact that the old motor spun a rod bearing, the motor was just seeing too much rpm, it easily handled the power. I also believe that they use the beefy eagle rods on their 2l setups, which is gonna get some CRAZY forces going on at 10k rpm. Lets say you went w/ a 35R which has better spool up, you could set the rev limiter at a nice safe 8500rpm and I bet the motor would last A LOTTTT longer.
Old Sep 6, 2005 | 01:52 PM
  #33
sleet's Avatar
Wow another EVO capable of 9's, I love this freaking car! Bushur is amazing.
Old Sep 6, 2005 | 02:52 PM
  #34
EvlEvo8's Avatar
SO if I give you my car and $3500 it will be a Turn Key affair? Is it safe to rev this thing that high? ANy package deals on a Block and a Head?
Old Sep 6, 2005 | 02:53 PM
  #35
Jeff_Jeske's Avatar
I dont know how the tranny and xfer can take that kind of abuse!
Old Sep 6, 2005 | 06:49 PM
  #36
LordEvoIX's Avatar
I have actually bought some new cores at this point from Mitsubishi. You can get an engine from us with no core for an additional $1250.
Help me out here....how much do we need to pay for a fully blueprinted and balanced Stage3 2.3L shortblock with all the goodies like Crower rods, ARP head studs, JE pistons etc? $4750?
Old Sep 6, 2005 | 07:57 PM
  #37
silverofs's Avatar
wow that is impressive revving that high with the stroker.. congrats on that setup & to the owner also.
Old Sep 6, 2005 | 08:08 PM
  #38
evo_il8's Avatar
thats awesome u guys never fail to impress, always improving on huge accomplishments
Old Sep 6, 2005 | 09:14 PM
  #39
byt's Avatar
byt
Amazing.
Old Sep 6, 2005 | 10:01 PM
  #40
Derek Baker's Avatar
Great Job David,
Now you just gave me one more reason why I need to win the lotto. Either that or sell some organs
Derek
Old Sep 7, 2005 | 08:53 AM
  #41
BigBadQuattro's Avatar
I'm sure when it's all set and done your back account will suffer 6k for this stroker
Old Sep 12, 2005 | 10:55 AM
  #42
David Buschur's Avatar
The complete shortblock, assembled with J&E's, Crower rods, balanced, balance shaft kit and painted is $3500, that requires you giving us your old block and main girdle back.
The cylinder head, our Stage 3, valves, springs, titanium retainers, SS o-ring, ported etc. is $1650, this requires your head core too.
Buy a set of head studs from us $110 and a head gasket $95 and I will bolt the two together for no charge and torque everything.
Total long block would be $5355. You would then put your cam, lifters, water pump, front cover oil pan and such on and drop it in the car.
If you choose to have us do it all then add $300 for front cover and new oil pump gears, $145 for t-belt and tensioner. Add another $100 for all the lubricants, $300 for a gasket kit and $1500 labor. $7700 total. That would include putting in a new clutch while we are in there, adding i/c pipes, different intake manifold or throttle body. Anything we have to take off anyways for the job we won't charge extra to change while we are doing the engine for the $1500.
David Buschur
Old Sep 12, 2005 | 08:40 PM
  #43
cary's Avatar
by total long block do you mean stage 3 fully built and stroked?
Old Sep 13, 2005 | 07:14 AM
  #44
sleet's Avatar
^ I think he means everything, the complete shortblock, cylinder head, plus the headstuds and head gasket.
Old Sep 13, 2005 | 02:16 PM
  #45
What I typed above is a total long block.
David Buschur
