Hallman Leaking....
Old Sep 10, 2005 | 08:55 AM
nhsean69's Avatar
So the general consensus is to go with the BOV connection over the wastegate and turbo connection?
Old Sep 10, 2005 | 09:08 AM
ez's Avatar
ez
Yes.
But I agree with SlowCar that cleaning/checking for debris is a good idea. I'll say this. If you have the MBC turned that far up, and you pressurize the end (in) port, the side port should not leak like that at 4-5 psi...even with the light spring. Something is wrong there.
The other case is that you still have a vacuum line somewhere connected that is allowing pressure from the intake side to enter the MBC side line with the bleed port. In that case you boost probably would have been screwed up from the beginning...
Old Sep 10, 2005 | 09:39 AM
nhsean69's Avatar
Anyone know where i can get the little caps i need for the nipples im not gonna be using??
Old Sep 10, 2005 | 11:01 AM
ez's Avatar
ez
Basically any auto parts store. Get the longer length caps so you have more room to clamp them with hose clamps. If I remember correctly, 4mm is the size you will need...or 3/16" should work if that's what they have. Make sure the turbo nipple is clamped well.
Old Sep 10, 2005 | 12:01 PM
bacalhau16's Avatar
does anyone have any problems with their in car controller (hallman pro rx) because the hoses are too long?
TariqEvo
Aug 22, 2017 11:38 AM
galantman03
43
Feb 5, 2017 09:54 PM
MitsuJoe
Nov 19, 2006 04:21 PM
eVo8sTaTuS
12
Aug 30, 2006 09:19 AM
