New upgrade path, need some help.
Ok guys, after some time using my external wastegate setup with the DNP header, I have removed it and sold it to one of the members. Now I installed my ported stock manifold, and ported O2 housing and I will keep both that way. Also now I will install an engine management possibly AEM , lets try something new, I always like testing things, and bought a new clutch just in case, EVO MR Disk. If my clutch fails again then its new in a box. Any suggestions on any additional mods that could add me some more whp on the stock turbo? No more manifolds for me, not for now, my ported things work great for now, we'll see.
Options:
Better Intake Manifold
Fuel Rail
Injectors
Post away and lets see positive feedback please, dont come and post nonsense or non-informative posts.
Thanks
Options:
Fuel Rail
Injectors
Thanks
If you are going to be getting some type of engine mang. then I would go ahead and upgrade the fuel system. Bigger injectors will help you turn up the boost and not have to max out the stockers. Also something that you might want to look into since you are getting the aem is an alky kit just to keep things cool under higher boost levels. The EMS I believe can control it and put it in at the right time automatically. <-- 85% sure of this might want to double check me though.
ThatchMoney
Feb 15, 2017 11:16 AM
Moore Auto
Evo X Dyno Results
19
Sep 4, 2015 01:53 AM
David Buschur
May 6, 2009 06:40 PM
