Mines ECU redline set to 8500rpm ?
MAX RPM
No its not safe to run a stock engine up to 8500 rpm , you would need to modify it. Its safe to run at 7500rpm on the stock engine.
Alexander
www.ajrperformance.com
Alexander
most stock 4G's safe rev limits is 7500rpm.
cause it use hydraulic valve lash adjust system.
It's a best solution for auto adjust valve lash on mass products,
but not good for high rev.
so want to use more rev. have to change solid type lash
adjust. but it make valve noise when engine cold, low rpm.
needless to say, change valve spring, cams(more duration and lift).
for more rev, change dual coil valve spring, harden valve seat,
harden spring seat and well balance need your engine.
