OEM Eng bearing grade differnces?
Old Sep 21, 2005 | 12:57 PM
Aby@MIL.SPEC's Avatar
Does anyone know the thickness dimension differences between bearing grades: 0, 1, 2 for the main & rod bearings?
TIA
Old Sep 23, 2005 | 11:37 AM
I found some main bearings out of a 4g64, luckily there were 2 different grades used on the main bearings. I was able to measure a difference between the 2 shells. These are the results of used bearings from ~99 4g64
Mains:
Grade 2 Grade 3
.07810" .07830"
.07810" .07825"
.07815" .07825
A difference of ~0.00015 between grades 2 & 3.
The reason why I didnt measure the other main shells, they looked bad.
Rod bearing thickness of grade 2 was .0586"/.0585"
enjoy
