Boost Question
Old Sep 27, 2005 | 06:01 PM
evoviiiny's Avatar
Boost Question
My boost controler is set at 20psi. When i added intercooler pipes the psi droped about 2psi. I know this is normal because the piping is bigger than the stockers. But if i crank the boost back up to 20psi wouldn't the turbo be working at 22psi? thanks
Old Sep 27, 2005 | 06:14 PM
3000ways's Avatar
Well think about this way, right now your car is running 18PSI (from what you said), do you consider it running 20PSI? So why if you turn the boost up to 20PSI would you now all of a sudden figure it's really doing 22PSI? Do you get what I'm saying?
Wait maybe I get what your saying, are you saying you have the boost controller set at 20PSI and boost dropped to 18PSI, therefore meaning you have to set the boost to 22PSI to reach 20PSI again? Do you have an electronic boost controller? A MBC wouldn't really have such a problem.
Old Sep 27, 2005 | 06:15 PM
2jzEVO's Avatar
don't worry, it'll be fine
Old Sep 27, 2005 | 06:17 PM
3000ways's Avatar
^ what he said
Old Sep 27, 2005 | 08:25 PM
evotino's Avatar
If the pipes have a larger diameter the volume is increased and the turbo will have to pump more air to keep the same pressure.
Old Sep 27, 2005 | 08:45 PM
bishiboy's Avatar
wait until you change the intercooler.
When I went to a 24x12x3 tube/fin I had to turn my boost controller down.
I had it set to 20psi before. After installation, it peaked at 26psi.
Another example of the stock intercooler being restrictive (with a stock turbo).
Old Sep 27, 2005 | 08:48 PM
SIC SIK SIX's Avatar
Originally Posted by bishiboy
not from 20 to 2.
Maybe a 1-2 psi drop. But 18psi is too much. You've got a boost leak. Check your connections.
you misread his post
