Help,2003 Evo8
Old Oct 2, 2005 | 09:48 AM
chenjianevo8's Avatar
Help,2003 Evo8
Injen Intake W/Up IC Pipe
High Flow o2 Housing Turbo Outlet
HKS RS Downpipe
TEST Pipe
HKS Silent Hi-Power Exhaust
I changed these parts on my E8,
and I use Perrin Fuel Rail with stock FPR,stock injectors,stock ECU,IS that ok?
What should i do?
NOW,my E8 has a problem,,when accelerate to about 5000r/min, my Evo jerks really hard like it hit a wall,
what is the problem?
thanks
Old Oct 2, 2005 | 10:23 AM
20valves20lbs's Avatar
HKS RS Downpipe
TEST Pipe
What should i do?
thanks
If its only doing his in higher gears most likely your hitting boost cut......turn down your boost
Old Oct 2, 2005 | 10:24 AM
TurboWill's Avatar
Hmmm, Maybe needs a new fuel pump?
Old Oct 2, 2005 | 10:28 AM
I did not change boost,its still stock boost
Old Oct 2, 2005 | 10:39 AM
Evo8564's Avatar
Does it throw a check engine if you stay on the gas, If so it is reading over boost. Even at 17lbs my evo did this with basically the same mods you have. Do a fuel pump and aflash and it should be fine.
Old Oct 2, 2005 | 10:46 AM
Thank u very much
Old Oct 2, 2005 | 10:49 AM
