2 Step/ Flatshift Question...
Old Oct 5, 2005 | 05:03 PM
TwStDeVo's Avatar
i have the T-Sport Flatshift controller(which is no longer offered) and i was wondering if the "no lift shift" feature is worth using? would this create a good benefit in drag racing? i plan on using the launch control and set it at 5500rpm, not sure if the flatshift feature is recommended. please post helpful opinions. thanks!
Old Oct 5, 2005 | 08:09 PM
timzcat's Avatar
no it is not. At 5500 it will cut more power then a lift shift because it will instantly drop your RPM down to 5500 and will affect spool of the turbo. At a low RPM like 5500 you are probably better off lift shifting. Bump it up to 6000 or 6200 and it may came back in line.
Old Oct 5, 2005 | 08:11 PM
gsujeff55's Avatar
yeah, 6200 and it will be worth it.
i flatshift with mine and i never see less than 17psi during shifts.
martinPL
Jan 26, 2016 04:21 AM
ctek
Oct 13, 2014 10:02 AM
Yoo Shin
Cobb AccessPORT
May 25, 2012 08:39 AM
Angry Slipper
Sep 17, 2010 08:12 AM
TwStDeVo
13
Mar 9, 2006 09:46 AM
