Is there a way to check the level of transmission fluid?
Yea open the tranny and pour the oil in a measuring cup
__________________
__________________
find the drain bolt on the transaxle (it'll be on the bottom and i think it says "drain"). above that there will a bolt smaller than the drain bolt. you take that out and you stick your pinky in the hole and the fluid should be just below the hole (on a level surface off course, a lift works the best). If you cannot fit your pinky in, get a small object like a popsicle stick or paperclip, bend it, and stick it in slightly to measure the fluid.
2003, 2005, check, checking, evo, evolution, evolutionm, f650, fluid, level, mitsubishi, stick, tranmission, tranny, transaxle, transmission
