After market Dampner pulley?
Never understood why anyone would do this as a modification. Most of the time the pulley will be too light and won't properly dampen the crankshaft vibrations causing premature failure of the main bearings.
Fluidampner only makes on for the 1g 2g 4g63t motors not the evo. The early cars use 2 belts that ride on the pulley and the evo only uses 1. I talked to them the other day and they said they were in development
Here's a link to the ATI Super Damper:
http://www.atiperformanceproducts.co...mitsubishi.htm
it's not about performace, this isn't a underdrive pulley, this is to cancel out vibrations at high RPM it helps keep the bearings alive.
Really no reson for this on a normal street car but for any high HP motor it really is a must.
Oh well, I'm curious, too, if anyone has tried it.
