Other V-Clamp Downpipes?
Old Oct 19, 2005 | 08:39 PM
dridge11's Avatar
I recently purchased a Vishnu Signature tubroback exhaust from ebay...got a great deal. The seller did not have a stock turbo, so the downpipe that came with it will not work (I knew this before I made my bid).
So, I have the Vishnu high flow cat, which has the triangle shaped 3 bolt connector on the exhaust side, but has a v-clamp connector on the downpipe side. Other than Vishnu, does anyone know of a 3in downpipe that will connect to a v-clamp Vishnu signature high flow cat?
Old Oct 19, 2005 | 09:29 PM
bolsen's Avatar
cmon meow, you can make anything v clamp... or not http://www.atpturbo.com/Merchant2/merchant.mvc
Old Oct 19, 2005 | 09:46 PM
ez's Avatar
ez
Looks good as long as we would be able to squeeze the extra length in. The hangers would have to flex quite a bit for that to work...
Old Oct 20, 2005 | 07:40 AM
dridge11's Avatar
Using that adaptor? It might be worth a shot, the adaptor isn't too expensive.
I'd rather just find a pipe with a v-clamp attachment built onto it. I guess I could always cut the one off the test pipe or vice versa. Or, EZ, I could probably take one off the mystery downpipe that came with it. It should be a perfect fit.
