Boost spike larger than expected.
Old Oct 21, 2005 | 10:03 PM
xenoturkey's Avatar
I finally got around to installing my TBE today. Espelir DP / CB with UR 3" cat. I had read some threads before about boost spiking when putting on a TBE. However, on this vaguely cool night (maybe 60 degrees) whenever I floored the gas I spiked 1.59-1.61 regularly for a second or two, then it dropped back down to a normal 1.35ish.
Is this safe? That spike seems awfully high, even if it only lasts a second. It set off the boost alarm on my blitz
I did some searching but no definite answers. Thanks in advance.
-xenoturkey
Old Oct 22, 2005 | 02:52 PM
xenoturkey's Avatar
bump
Old Oct 22, 2005 | 03:01 PM
vboy425's Avatar
you will be fine, it doesn't matter where it's spike, it's what constant. trust me. my spike to 23.3 psi and drop down to 22psi hold it ther eunt il 6480rpm drop down to 20.5-21.5psi until 7458rpm. Thi s s base on the Datalog from my Zeitornix.
