Some advice please...
Old Oct 26, 2005 | 01:10 PM
Twitch's Avatar
Think I am going to go with 272/272 setup + adj Cam gears...
I was considering 280/280 but maybe a bit to aggressive. Not to concerned about the lumby idle. I don't have a reflash. I really can not go without my car long enough to have that done, not to mention I have been upgrading pretty fast and I don't want to have to keep having it reflashed. I do have the AFC-II installed but have not made any changes with it yet.
My questions are...
Do I need the reflash to run the cams or will the S-AFC II be good enough?
What degrees should cam gears be at for best 272 performance?
Thanks for the advice in advance
Old Oct 26, 2005 | 01:14 PM
2hot2handle's Avatar
if you can live a little lumpy idle, you should be fine. but you wont get the most out of it w/ just an AFC.
