EVO mems, brag a lil', post your mods if your over 350awhp...
Originally Posted by gonzo
So your saying that him spinning or hooking up would only be a difference of a few mph? What is your e.t. when you spin all through first?
look at my sig for mods and dyno sheet. That was done without methanol and at 22-23psi. I have been wanting to do a 1/4 mile run but it rained last friday and moroso is closed this weekend because of the hurricane. I hope they open next week, I am dying to see what I can pull off with race gas and around 25-30psi.
Here are some vids:
http://72.41.83.159/video/HKS280cams.wmv
http://72.41.83.159/video/LPIexhaust-Joeymia.wmv
http://72.41.83.159/video/dyno10-01-05.wmv
http://72.41.83.159/video/dyno10-14-05.wmv
http://72.41.83.159/autox/Homestead-9-25-05.wmv
here is my favorite mod
Here are some vids:
Originally Posted by evolsk8r
Dyno numbers: 365awhp/334tq
Mods:
-Helix intake
-Helix turbo back exhaust
-Helix o2 housing
-Helix ic pipes
-FIC 650 injectors
-SAFC 2
-Greddy profec b spec2 boost controller
-GSC 272in/264ex cams
-megan exhaust manifold
-Walbro 255 fuel pump
Best time 1/4 mile is 12.7 @ 108 spinning the tires off the line (need new tires)
Mods:
-Helix intake
-Helix o2 housing
-Helix ic pipes
-FIC 650 injectors
-SAFC 2
Are u running that quarter with 18's??? That'll slow you donw and explain the time+mph disconnect. . .otherwise, INVEST IN SOME TIRES MAN!!!
I've never spun in 1st. . of course I've never pushed her. . .
No hp, but probably 20-30wtq. I was already tuned with my S-AFC, so the flash was just to raise the rev limit so that I could hopefully hit 11s. Another side effect of the flash is that it gives back lost torque in the mid-range, so if I were to go dyno now, instead of 294whp/269wtq, I'd probably get 295whp/285wtq, if not a little better on the torque side.
You keep telling everyone here that their dynos #'s don't match their trap speeds. But you think you now make 20-40 more whp and have not dynowed the car yet! Last post you sayed you are around 330-340, how do you know that? A flash won't give you 20 to 30 whp on your particular car. You need to dyno your car and don't guess anymore. You guess alot and that is wrong.
Just to prove you wrong, my car has gone 12.99 at 106. How many whp you think I have? And you will probably answer 270-280 based on your trap speed theory.
That would mean you are making more hp than me, right? Because you trap 12.01 at 113! But I have cams and a few more mods than you have. And my last dyno was 335. How is that possible? More mods, more whp, bad dyno? yet you are 1 full sec quicker than me and near 7-8 mph faster. But I bet that if I give you one car lenght head start from a 45 mph roll, I will drive around you by the time I hit 90 mph! Trap speeds and ET's are like dyno's. A slow shifting driver will put a question mark on your trap/et theory. It does not allways work that way, yet you swear by it. Quit that.. I have pulled on many other Evos that trap much more than me. And I was not even tuned right back then. I was traping 13.2's at 104-105 and driving around Evos doing mid 12's at 110+. I am not a good driver, all we need is supporting mods, and the car will do the rest to be fast. I hope this makes sence to you. It has not yet, but I hope it will.
Talk about spinning and maybe some ****ty shiftings, how about me, 12.2 / 123 mph on 2.0 60' on balb stock tires. Now that's spinning to the line. I'm not on stock turbo, however.
Originally Posted by 04AWDTURBOEVO
You are seriously confused.
The only thing I'm lacking is a dyno on race gas. I'm sorry that I haven't done that for you yet, but the last 2 times I dyno'd, I only got 3 runs, and that's just not a lot of time when you're trying to dial in your pump gas tune. Race gas is also not available at the last place I dyno'd either, so it's not the easiest thing to do. I am assuming that I put down around 330-340whp when I'm on race gas based on the typical 30-40whp gains over pump and the fact that a 113mph trap matches 330-340whp. All the factors point to this as a logical solution.
Now, on to the bad driver theory. Yes, of course, a bad driver can seriously affect ET, but a bad driver will have a tough time affecting MPH negatively. Look at G20. He's having trouble hitting 11s, yet he's trapping 123. Why is he trapping 123? Because he's making a !$#*load of power. Notice how his trap doesn't match his ET? That's due to bad driving or terrible traction. Bad driving and/or terrible traction does not run a 12.7 @ 108, because that's pretty decent driving there. Likewise your 12.99 @ 106. That's not good driving, but that's on par with stock IXs and stock VIIIs. Hell, I ran 13.17 @ 104 stock with a bad 60. That's also right on par with you, but 20-30whp lower. So, yes, I would guess you are around 270-280whp. Talking about how you pull on people on the highway is pretty lame. Anyone worth their salt knows that 1/4-mile trap speed is the TRUE measure of power delivery...not a dyno.
There are too many variables involved here. (Altitude, track prep, tires, rim size, driver, engine state of tune, humidity, gas, vehicle weight, blah, blah, blah, blah, blah) This argument will always go on without an end. (As it always seems to)
....I'm going to put in a gazillion parts and make a gazillion hp, and put half a gazillion down to the ground and run a 10 second quarter mile! I win!
Either way, the mph doesn't match the dyno results. 108 indicates 280-290whp, whether spinning or not.
So yes, my dyno numbers and times do match.
Originally Posted by shivaswrath
here's a stupid but germane question:
Our track is very hard to get good times, especially in the summer(it's the desert). They never prep the track for us either, so traction is always a problem. I guarantee if you brought your car and ran it here, you wouldn't be running the times you are at your track. My best trap is 111, but are consistent 107-108 with 12.7-12.8 times. Here is my timeslip and dyno sheet:
Now, take my care for example. You are saying that I would run slower there than I do here. Ok, that's probably true, but again, that's because I'd be making less power there than I do here...not because of the track. You say it's not prepared well, but you cut a 1.81 60'. I cut a 1.92 after spinning all through first, hit 2nd and kicked sideways, yet proceeded to run 12.36 @ 112.6. Notice, I was .2-.3s off my best times, but my mph was still there.
I see the dyno sheet, but that doesn't matter to me. What matters is your trap speed. If you came down here in 60-degree weather at 500' above sea level, you could probably dyno 330/360, but you'd also be able to run 113/116mph. I also am not sure whether you're doing runs on 91 or 100, so I don't know what mode you're in: 330whp or 360whp. If you hit 111mph on 91oct, than that is much closer to matching, but if it's on race gas, then nah. You said even on a 1.7 you hit 108...so how did you hit 111? What changed for that run?
10-29-05 Pd Tuning Mustang dyno : new numbers 309hp 315ft/lb (my old numbers were lil higher. recalibration or something nick said)
well mods are:
3" tbe
hks 264 cams
xs engineering fmic
custom ic piping
aem ems
gm boost solenoid
12.2@112-113's on pump was with my last tune. i'll be hitting 11's on pump in november.
well mods are:
3" tbe
hks 264 cams
xs engineering fmic
custom ic piping
aem ems
gm boost solenoid
