Question about APS Bov!!!
Don't get on the man for replacing the BOV. Mine leaked like a freakin' sieve until it got below 10psi. It's inevitable insurance to buy the BOV and the APS unit makes it bone simple. Just screw on the right hoses and she works great. No screwing around with ANYthing.
In my case (YMMV), the sound was strikingly evident and louder than stock. Perhaps that's because my stock was so bad. People near the car and in the car all noticed it immediately my 16 year old shook his head and my 12 year old smiled ear-to-ear. Me? I smiled cuz it didn't leak at boost leak test any damned more.
It's the stock intake that is masking the sound. Put a intake on the car or at the very least put in a drop in filter (HKS or K&N) then you'll get some more sound out of it.
I turned the allen screw all the way in (clockwise) on my APS bov, just enough so I could still tighten the nut on the threads. It runs a lot smotther in between shifts that way....
The sound they hear is the rushing in of air (through) the intake. It becomes more audible when the stock configuration is changed.
I used to have a supercharged M3. It had a recirc 'bov' and the only sound was from the intake.
You have to remember - a turbo/supercharger is nothing more than a pump.
Originally Posted by dubbleugly01
You're reducing your BOV's ability to vent by doing this. It may run smoother during shifts, but it could also be stalling your turbo during shifts, which is a bad thing.
Could you elaborate on this?
Thanks...
Originally Posted by kapolani
Stalling your turbo?
Thanks...
Thanks...
I really don't think it's the BOV that makes the sound people hear when they install an intake.
Originally Posted by MuslimEvoFreak
Look man, I bought the Bov because other bov's stalled on our cars. I looked up this bov and saw that APS got rid of the problem of our car stalling on VTA bov's. This bov is recirculating when not on high boost, but when you have high boost applications it VTA's. I like the sound and all but thats not what I am worried about. BTW, I didn't really do anything to the nut. I unscrewed it by hand a little bit and then screwed back to what it was. Thanx though for your help......
Well, Actually, The APS is an awsome unit from what I hear.
First stage recirculates till the boost crosses a certain level, then it VTA.
One word of caution - if you change or put the spring in yourself have to seat the spring not just insert it.
OK, with regards to not really being able to hear a BOV.
I guarantee you will hear the HKS SSQV. You can scare small children, clear the road of deer and generally make an *** out of yourself with that BOV. Its incredibly loud.
I have one sitting in box FS with a full ver2 kit
the turbo takes low pressure air, from the intake, and compresses the air by spinning really fast (think about a multiple speed ceiling fan), and moves it on down the intake pipe. The faster a turbo spins, the more air it can supply to the engine. When the throttle body closes abruptly during a shift, the air has nowhere to go except through the BOV. If the BOV doesn't relieve the pressure and give the air somewhere to go, the air will actually go backwards through the turbo, slowing it down dramatically, very quickly. It's also called surge, and is very damaging to the turbo's longevity. It's a bit simplistic viewpoint, but I hope that helps.
I understand.
What are the symptoms of 'surging' etc...?
Okay.
I understand.
I understand.
acute symptoms - turbo failure.
Originally Posted by xballsport
can the turbo be damaged with the stock bov on backwords?
chronic symptons - poor part throttle driveability, for instance uneven power delivery under constant throttle input, or abrupt loss of power under slight lift of throttle, just to come back a split second later.
Now I understand.
If the BOV were 'turned' down too low (making it harder for the piston to open) the built up air wouldn't have any place to go. Thus going back towards the turbo. You have to lessen the springs tension to allow the air to recirc or vta to relieve the stress on the system.
Thanks!
