Going to be rebuiding my engine soon and had some questions
I have some plans for 20g turbo and I want to make sure my engine can hold. I will be pusing around 350-400hp on street setup and around 500 on race setup. Currently the only internals I have upgraded are the cams. I was thinking of purchasing the following:
ARP Head/Main Studs
AMS spec stock bore and compression ratio Ross Racing Pistons
Eagle Rods
Crower Valve Springs and Titanium Retainer
I'll also try to get some port/polishing of the head as well. Any other suggestions on this build up?
Few more questions maybe someone can give some input:
With the cost of pistons, rods etc.. a few hundred more will get me a stroker kit. Will it be worth it with a 20g?
Will 750cc injectors be enough for for 500whp?
ARP Head/Main Studs
Eagle Rods
ARP Head/Main Studs
AMS spec stock bore and compression ratio Ross Racing Pistons Wiseco makes an excellent piston at a better price.
Eagle Rods
Crower Valve Springs and Titanium Retainer Revolver Springs and Retainers would be a better choice. A lot of consideration went into thier deisgn.
I'll also try to get some port/polishing of the head as well. Be very careful here. You can adversly affect drivability. You are probably better off leaving it alone. Porting will also require a complete valve job and will add significant cost and time to the project.
Go with Cometic for the head gasket.
Change the cams to Revolver cams. The increased lift and duration profile will improve drivability over HKS cams. With the larger turbo you will also improve your spoolup. I hope to show the difference between the 272 cams and Revolver's cams very soon. I am simply unhappy with HKS 272 cams and believe the Revolvers will make a big difference in drivability and power
Tough question. You will gain a lot of low end torque but the stroker is a lot more work and cost in comparison to your current plan.
Yes, depending on if you are talking about alky injection or not and what tuning method will you be using?
ARP Head/Main Studs
Eagle Rods
If you take it apart you minds well remove the balance shafts, balance internals, and for $700 more do the stroker if you have the cash. OR like the poster above said, if thats all your going to do then leave the bottom end alone and spend the money on a clutch a TRE trans.
If you chose to remove the balance shafts you will run the risk of an oil pump failure if it is done in the traditional manner.
I would not leave the bottom end alone at 500whp. You will break a piston, it is only a matter of time. The pistons are by far the weakest link in the bottom end.
Originally Posted by timzcat
My opinion and comments.
As for swapping the cams out I am very happy with my hks 280's. I have 0 driveability issues. I must have a freak of a car because everyone is amazed on how well my car idles and performs with the hks 280's.
Originally Posted by mchuang
for 350 to 400 you dont need to rebuild..ported head wouldnt hurt, but rebuild why?..4g63 2nd strongest japanese motor made next to supra
Originally Posted by evo_il8
i doubt ur gonna be able to push 500whp out of the 20g even with race gas
ARP Head/Main Studs
Eagle Rods
ARP Head/Main Studs
Eagle Rods
Here is my 2 cents:
First, I think if you do all this work to your bottom end, you might be disappointed with gains you end up getting with the 20g. If you go with the stroker, at least you gain a tremendous amount of grunt and spoolup. That will make you feel happy after dropping so much cash.
Also, don't underestimate the need for top notch machine work and assembly. The road is littered with failed rebuilds and rebuilds that burn excessive amounts of oil. If you have a reputable shop do it, make sure they will stand behind it for build related failures or problems.
I agree with Timzcat about porting the head. My numbers below are with stock head, stock valves, stock valve springs, stock intake manifold, stock throttle body, stock maf, and 3 inch intake piping. At 27 psi! Save your money on the head-related work and get the stroker kit.
750cc injectors will get you to 500 no problem if you are using the stock ECU. For some reason that I still don't fully understand many folks claim that the AEM ems injector drivers are not as efficient as the stock ECU. So if you are going with an AEM, go with 880s. I have AMS 880cc injectors with the stock ECU and they are fine at 540whp and 492wtq (but the Walbro 255 is close to its limit).
How do you figure. He will need a new crankshaft for a stroker. He will also need the block clearanced. This will also require the removal of balance shafts and the internals balanced. This will ultimately add up.
The total cost of machine work from my build was $1000, which included a .020 cylinder bore, decking the block, a valve job, balancing the crankshft, gapping the rings, and hanging the pistons on the rods, chearances, and all the other little things I'm not thinking of.
I am very interested into looking into your claim of oil pump failure due to the removal of balance shafts. This topic came up in relation to Ferrarokid's engine failure in the USCC but that was the first time I had ever heard of it. Could you point me to any discussion of this issue that you know of?
IMHO, us mortals on the boards often get incorrect information about the causes of engine failures. I hardly blame tuners and shops for being misleading, as so many members are looking for any excuse to flame them. However, over and over again, I hear of the reasons of engine failures being things like fuel slosh, oil pump, fuel pump went out, bad gas, EBC got stuck on 40psi, etc. Sure, sometimes it is true, but many times it is just convenient excuse to save face.
Smoggy
Originally Posted by Smogrunner
Timzcat,
Smoggy
Smoggy
with couple things i have planned I am pretty confident i will be able to reach that goal.
