Calculating Race gas/Pump gas Mix
Check out this site it tells you how much Race gas to mix in your your pump gas to achieve your desired Octane rating..... also tells you the cost per gallon o fthe desired blend
http://ranney.com/~mjr/fuel_blend.html
here is a site that does two part gas mix calculation (like 91 w/ 100)
and other things like gas mixed w/ methane and such
http://www.easyperformance.com/Octan...d_Frameset.htm
