HELP.....Service Engine Light
Old Nov 16, 2005 | 09:42 PM
gaulrich2003's Avatar
I replaced my Upper/lower IC pipes and catalytic converter last night. I have an O2 fix on the pipe after the now 3" straight pipe. The straight pipe I replaced the catalytic converter with has a bung for O2 fix but I plugged because there is already an O2 fix after the new straight pipe. This evening my service engine light came on.
Should I: 1. Swap the sensor a place in the new pipe and close the old hole.
2. Buy one of those 12 volt O2 fixes from Buschur.
HELP.....
Old Nov 16, 2005 | 09:47 PM
WHTEVO's Avatar
man that was hard to read. anyways, i would just do a mechanical o2 fix and quit messing with the electrical stuff. it is cheaper anyways. good luck.
Old Nov 16, 2005 | 10:11 PM
Jakeg97's Avatar
Originally Posted by gaulrich2003
HELP.....
so is this the fix you did?
https://www.evolutionm.net/forums/sh...d.php?t=114931
