Question on i/c piping
Ive been searching and either ive used the wrong set of terms or either there isnt info on this yet...
but what would be better for a custom i/c setup.... 2.25 stainless 304 or 2.5 stainless 304 (also can get in aluminum)
and whats the pro's and con's to smaller/larger pipe sizes
thanks in advance
Andrew
but what would be better for a custom i/c setup.... 2.25 stainless 304 or 2.5 stainless 304 (also can get in aluminum) and whats the pro's and con's to smaller/larger pipe sizes
thanks in advance
Andrew
aluminum is lighter than stainless, and offers enough strength to hold all the boost you care to thow at your motor. Pick aluminum over stainless. The larger IC piping will offer less pressure drop at elevated hp levels. The smaller IC pipes fit better in tight spaces.
