boost problem
Old Nov 22, 2005 | 10:15 AM
meyaw1980's Avatar
boost problem
im experiencing some problems with boost .. first ill talk about my mods i have :-
1- injen intake kit
2- invidia downpipe + catback + stock cat-pipe
3- Evo MR BOV
sometimes not all the times when im on 3rd gear and i go WOT i can feel the boost is coming after 3000 and 3500 RPM .. first it is high then it slows a bit then it continue to raise again .. dont know whats wrong but u might help guys ..
also some times when i brake and of course hitting the clutch when i stop suddenly i can feel o little vibration which is different than usual and the RPM drops a little bellow 1000 RPM ..
ill be thankful for the help
Old Nov 22, 2005 | 10:25 AM
Fa$[- a$ $hi[-'s Avatar
my boost went high (23psi) then low (20psi) then to normal (22psi) when my clutch started slipping. all this occured between 3k to 3.5k rpm. if it feels and sounds like the engine is speeding up and the car is slowing or no change in speed, then your clutch is slipping. give it a few more days of getting on it. it'll be more prevelant and you'll definately tell the clutch is going.
Old Nov 22, 2005 | 10:33 AM
meyaw1980's Avatar
first u can feel high boost then u feel like the car cant holds it then it raises again .. u can see the RPM slows a bit at 4000 RPM then the boost will rise again ..
by the way its not all the time .. on cold days i cant feel this .. because the climate here in the middle east is hot
