my ams stg3 dynoed at 310awp/480FtLb
Old Dec 16, 2005 | 05:55 PM
her0's Avatar
my ams stg3 dynoed at 310awp/315FtLb(corrected)
mods:
19psi with 91 octane
264/264 hks cams
680cc injectors
255lph
ams turboback
ARP studs
ams FMIC
afc, mbc
anyone else think my numbers are a little low?
Not sure if I can run anything over 19-20psi on this 91oct crap. I can scan the graph if anyone is interested. Any thoughts??
Old Dec 16, 2005 | 06:03 PM
evolsk8r's Avatar
Are you sure your torque number is right? That's insane if it is.
her0's Avatar
i mean 315ftlb
315 FtLb
Old Dec 16, 2005 | 06:05 PM
Hotshot940's Avatar
uhh, well your titles says 480. lol.
C6C6CH3vo's Avatar
Maybe dyno set up for different gear than used during registered pull?
310 to me aint bad at all for a 9.8 on 91. I have no idear whats up with that torque.
Old Dec 16, 2005 | 06:06 PM
Stinkapuss's Avatar
Sounds about right for a dynojet and 19-20 psi. Car should trap 110-111 with that hp.
Old Dec 16, 2005 | 07:09 PM
bacalhau16's Avatar
no i think with the addition of cams, that these numbers are a little low. unless this is on a mustang dyno like buschur's. where did u dyno and what kind was it?
Old Dec 16, 2005 | 07:57 PM
Vroompsh's Avatar
those numbers are about right, and the torque is just right for straight 264's...look at my numbers, i'm peaking at 24 psi too
her0's Avatar
dynoed at greenlight in san deigo
dyno dynamics dyno
Old Dec 16, 2005 | 08:42 PM
Warrtalon's Avatar
Originally Posted by her0
dyno dynamics dyno
Damn, dude, all this time we thought it was a Dynojet. That is absolutely CRITICAL information. DD dynos read way lower than Dynojets, so you're looking at 345/350 or so on a Dynojet more than likely. I think that's plenty of power, but you really should compare with other Evos on the same dyno to know for sure...or, like we always say, go get some trap speeds to verify.
Old Dec 16, 2005 | 08:44 PM
fromWRXtoEVO's Avatar
It sounds a very credible number to me.
Old Dec 16, 2005 | 09:05 PM
her0's Avatar
fixes mistake
sorry it was a mistake. i fixed the post.
Old Dec 16, 2005 | 09:32 PM
bacalhau16's Avatar
ya, if its on a dyno dynamics, then i would have to agree that they dont seem off, and i would also say to go to the track and make a pass. A couple good runs and a look at ur trap speeds should say it all.
Old Dec 16, 2005 | 10:43 PM
Cirrusly Evolvd's Avatar
What ya should have done was do a baseline run on that same dyno and then another run after your mods...then you would have a hard number as to how much hp you gained. You can't compare apples to oranges.
Old Dec 17, 2005 | 09:23 AM
Turbojunkie's Avatar
go run some 1/4 mile times and then post back
