View Poll Results: Do you have a new head gasket?
Yes
9.68%
No
56
90.32%
Voters: 62. You may not vote on this poll
Poll: People With cams look inside
Old Dec 19, 2005 | 09:25 AM
MitsuEvoIIX's Avatar
Have you replaced your headgasket when doing cams/headstuds?
Old Dec 19, 2005 | 09:37 AM
Derek888's Avatar
I did
Old Dec 19, 2005 | 10:33 AM
wingless's Avatar
I don't understand the relationship
Old Dec 19, 2005 | 10:58 AM
C6C6CH3vo's Avatar
I only replaced the bead of sealant around the valve cover
Old Dec 19, 2005 | 11:00 AM
evo8_m3's Avatar
still running stock head gasket
Old Dec 19, 2005 | 11:44 AM
anjapower's Avatar
I suppose because many argue you shouldn't remove headstuds unless you're replacing the headgasket. I am guessing the original poster wants to know if the one at a time replacement method of headstuds is safe
Old Dec 19, 2005 | 12:28 PM
yea i want know who replaced the gasket when they pulled the cams and replaced the studs
Old Dec 19, 2005 | 06:30 PM
TEXSRT4's Avatar
when you replace the studs your going to want to replace the gasket. if your not touching the studs, dont worry about it. atleast thats the logic that comes from wrenchign on other vehicles
Old Dec 19, 2005 | 06:32 PM
ct9a gsr's Avatar
1st time - installed camshafts and arp headstuds using the 1 at a time method
2nd time - installed camshafts and arp headstuds while the head was off of the block, replaced the HG w/ a stock HG.
Never had any issues or problems with the way it was done the 1st time.
Old Dec 20, 2005 | 01:21 AM
Evil EV0's Avatar
Nope didnt replace the gasket when doing Cams, Valvesprings/Retainers. I probably would if I messed with the head though.
Old Dec 20, 2005 | 01:44 AM
SRT-TO-EVO's Avatar
Do it.....better to be safe then sorry you know.
Old Dec 20, 2005 | 03:43 AM
USAF_STi's Avatar
when we did mine we used the one head stud at a time method. the car is still running great.
Old Dec 20, 2005 | 04:09 AM
EVO_8's Avatar
One head stud at a time, torque to correct value (can't recall at the moment what the value is) and it should be fine. Make sure there is no pressure in the cooling system, simply take off the radiator cap. I did it like that, beacuse AMS does it the same way. If they do it, I had no fear.
Old Dec 20, 2005 | 04:44 AM
nirvevo's Avatar
I think some people confuse the Valve Cover Gasket with the Head Gasket.
If the 1@a time stud method works, and I believe you can trust it (Especially if it's true that AMS uses it) , it would be pointless to replace it unless it's leaking, seeing as you aren't removing the Head.
The valve Cover gasket would only need to be replaced if it was old or damaged. In most situations, I can't imagine an VIII's gasket to be either
Old Dec 20, 2005 | 10:43 AM
Evil EV0's Avatar
^ I agree, I think people are confusing the 2. If you dont mess with the head why replace th gasket. Maybe this is some newbie info but what the hell...When you replace the cams, all your pulling off is the Valve Cover, you are not pulling the head off. Personally I would be more worried about valvesprings and retainers when replacing cams than I would be about the HG...just my .02 cents.
