boost spike?
Old Dec 22, 2005 | 12:46 PM
evorevolution's Avatar
boost spike?
I was out this weekend (in chicago) and it was rather cold that day. I have the hallman pro-rx manual boost controller . For winter I tuned my boost all the way down to about 14psi. I was out on the highway messing around and noticed this:
I hold 14psi till about 5k when it hits that it spikes to about 26-28psi????
Is the spring in the mbc just frozen??? any1 else in cold climates having/seen this?
Old Dec 22, 2005 | 01:34 PM
Warrtalon's Avatar
That's very strange. I'd double-check all the hoses.
Also, why in the world would you turn boost down to 14psi in the winter?? YOu can run MORE boost than normal in the cold weather without knock.
Old Dec 22, 2005 | 01:37 PM
dan628's Avatar
He probably turned the boost down so the car wouldnt have as much power so he wouldn't spin out if was icey out...
Old Dec 22, 2005 | 01:45 PM
boost spike
yea i turned it down bc its been snowing a lot lately. And yes all the hoses are secure and hooked up right. It never did this untill recently now thats its been so cold. I also called a buddy of mine thats running basically the same mods on his evo with the pro-rx also and he is having the same exact proublems????
Old Dec 22, 2005 | 02:36 PM
HiRevnVIII's Avatar
Happened to me too, only after a carwash when it was like 2 degrees outside. Take off the mbc, take it inside for a bit, then put it back on, i was cured, only I was boosting way over 28 psi, and i got some major fuel cut, you should have too. I would think this would happen right off the bat, not when your car is warmed up though...
